Cutting Threads moving away from headstock , running lathe in reverse - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21
    Feb 2015
    Florida
    674
    174
    A slug of 4140 isn't what I would call mild steel. The novice threader would be better served practicing on a slug of some gummy hot rolled steel. It would teach him (or her) the importance of a sharp tool, the correct depth of cut and lubrication. Once the novice has mastered chucks of HR, then most anything else will be a breeze.
  2. Likes lalatheman liked this post
  3. #22
    Feb 2004
    peekskill, NY
    25,118
    5026
    Delrin is a good practice material. Pretty forgiving. Brass likewise.
    I avoid the term 'lubricant' because then folks tend to put a lubricant on the workpiece.
    "Cutting fluid" is better. For hot rolled steel one of the best is that black sulfized cutting oil,
    available in small containers in the HD plumbing section.
  4. #23
    Jun 2012
    Michigan
    11,325
    3877
    3995
    We always called a small piece of steel/material that did not have a designated need purpose a slug..just means one can use it for any purpose.
  5. #24
    Sep 2010
    moscow,ohio
    6,284
    643
    2074
    worrying about a chuck coming unscewed was never a concern of mine for a relatively low speed low force operation like threading.
    excellent practice is old bolts...turn of the head, rechuck it and pick up the thread...
    encompasses several things at once....try and youll understand the challenges.
    obviously you want bolts that are not fully threaded.
    you really shouldnt be reusing all those old head bolts anyway...
  6. Likes lalatheman liked this post
