I am going out of my mind! My machine doesn't exactly cut the correct threads per inch it is setup to do. I set up for 14 tpi and the scratch pass doesn't line up with the gage. At 7 threads its off about half a thread. Somewhere between 14.5 and 15 tpi if I try to measure with calipers.
I can't find anything wrong with the setup. The first lever is in A the second lever is in the last hole.
Under the cover I have a 20 tooth going to 80 going to 56 input to the qcgb.
I can't figure out how it COULD cut this if I wanted it to. Is my setup right? Something else wrong? Lathe just too worn out to thread?
14 tpi - Album on Imgur
