Paula
Titanium
- Sep 16, 2005
- Indiana, USA
Here's something that might be of interest to owners of the smaller SB lathes that use the old style feed reverse lever -- the one that uses the square-head bolt to lock in position.
Since I had the headstock for my 9A all taken apart, I decided it would be a good opportunity to make a couple of small improvements to the feed reverse lever. One thing I don't like about this style is that you have to kind of guess where the neutral position is. There are adjustable stops in the forward and reverse positions, but when you want to take the feed out of gear, you have to just kind of feel around for a position between the two extremes. It's not a big deal, but I decided it would be nice to have a detent that would center the gear tumbler in the neutral position without my having to guess or look down at it.
So, what I did was to drill and tap a 5/16-18 hole thru the back of the headstock, just behind the reverse lever bearing housing. Note: the feed lever should be removed before drilling the hole! Also, I had to counterbore the hole deep enough to clear the shank of the tap:
I purchased a 5/16 spring-loaded ball plunger from McMaster-Carr. This one has a 6 to 17 lb. end force:
Before installing the ball plunger, I temporarily installed the reverse lever and the spindle to spot the location of the detent on the reverse lever bearing housing using a 17/64 transfer punch. Here's what the ball plunger looks like installed:
I used a center drill to make a small indent on the feed lever bearing housing at the previously located point:
The feed reverse lever was then reinstalled in the headstock, and the ball plunger adjusted for a good "feel", then locked in place by jamming a 5/16-18 set screw in behind it.
The detent works very well! It gives a positive indication by feel when the lever is perfectly centered between the forward and reverse positions. An additional improvement I made was to replace the square head bolt with a large wing bolt, so that the lever could be tightened without having to grab and fumble around with a wrench:
A simple little improvement that doesn't take long or cost very much.
Paula
Paula
