Did SB Ever Plate Any Parts?
mcload
Hot Rolled
Nov 5, 2007
Houston, Texas
Hello crew; I hope everyone is well.
I'm plugging away slowly on my '59 Mod.B 9", and I'm still at the stripping/painting stage.
Does anyone know offhand if SB ever plated any of the lathe parts in cad, zinc, or nickel?
Probably my imagination, but I thought I've seen flat pulleys (headstock or drive) that look like
plating of some sort had worn off in places. Or were they just made in ready-to-rust cast iron and
shipped that way? Sorry for the dumb question, and thank you in advance.
PMc
I don't believe any of my South Bend stuff was plated. But I have other machines that were, and I wouldn't mind refinishing some pieces. But I have zero knowledge on it, or what cost. If you get into it, or anyone else, I wouldn't mind seeing info.
I suspect the satin finish is a chrome plate of some type.
I have run milling machines that have chrome plateing on the handles. It's great until it starts flaking then it's only good for cutting you.
From my experience with plating classic auto parts, I would probably choose hard chrome (unpolished) for the pulleys. Zinc would be cheapest but it's soft. Cadmium flakes and absorbs into the cast iron. Nickel would be over-doing it, and again, probably soft. Clear anodize?
Most places will have a minimum charge and I don't thing it would be worth it unless I had a lot of parts to do.
Thanks for the replies.
PMc
View attachment 295332 View attachment 295334
And I think the clean(er) spots are from running a multi-groove serpentine belt
+1
My 10L has features developing on the cone pulleys like this, and I have a serpentine belt. If the tracking is good, the
belt always stays in the same location on the OD of the pulley. The rubber is pretty abrasive.
