I have and i need help with the 2 speed motor belt tension. It used a 5L belt from the motor 2 step style 2 A pulley to the 2 step counter shaft pulley, Mine has a cast tab on the pulley side with a pin and a threaded hole looks similar to an automotive spring loaded belt tensioner. On the 2 speed motor systems is the belt normally tensioned with a tensioner to make changing speeds easier. If your reading this and have some sort of spring loaded tensioner I can duplicate a tensioner from a picture, none of the SB 9 inch manuals show any tensioner but most pictures are of the single speed counter shaft pulleys and not the 2 speed stepped pulley.
