Does anyone sell Dial Indicator Clamps for SB Heavy 10 - 10L?
Results 1 to 14 of 14
    Aug 2015
    39
    Default Does anyone sell Dial Indicator Clamps for SB Heavy 10 - 10L?
    Was looking to buy a Dial Indicator Clamp Mount for my 10L lathe. I found one for SB 9 and 10K lathes, but so far (with the exception of a 3P Plastic Printed version) I have not found one of this design for a 10L lathe. Would prefer a Metal clamp.
    Would the 9/10K version fit a 10L, or could that version be modified to fit easily? Unfortunately, I currently don’t have access to a working milling machine.
    Does anyone manufacture a clamp of similar design specifically for the 10L?
    Thanks.
    Oct 2015
    Virginia
    462
    14
    98
    There's a guy on ebay who sells them. I've had several and they are nice enough.
    I'm looking for a link to the one in question, but here is one from another seller. It is 3d printed.
    SOUTH BEND HEAVY 10 METAL LATHE DIAL INDICATOR MOUNT CLAMP LOGAN 850 3D Printed | eBay
    Here is the seller I was originally referring to. It looks like he is out of Heavy 10 ones right now but lists them often.
    SOUTH BEND 9 & 10K Z AXIS DIAL INDICATOR MOUNT DIGITAL READOUT | eBay
    Aug 2015
    39
    Thanks for your reply and links.
    I have seen the 3D printed version, but would prefer a metal clamp.
    I also found the one on EBay for 9/10K lathes. Did not know that he also made/sold one for 10L lathes even if out of stock.
    South Bend lathe dial indicator and clamp for 9"&10K 680474114276 | eBay
    Since my original post, I sent a “Contact Seller” message asking if he had a 10L version or if the 9/10K one could be modified to work.
    Edge Technologies also makes one, but it looks to be a scissor clamp, which would likely work, but I would still prefer the cleaner looking clamp discussed earlier.
    What dimensions keep the 9/10K version from fittings 10L?
    DC
    Sep 2010
    moscow,ohio
    5,579
    540
    1760
    For a dial indicator you can just use a mini mag base.
  5. Likes Vladymere gr liked this post
    Feb 2015
    Florida
    261
    45
    Quote Originally Posted by iwananew10K View Post
    For me, a mag base is too uncertain... "Did I just bump that...?" I prefer a solid clamp. "Did I just bump that...? Who cares, it is clamped so solidly that a bulldozer could run into it and not move my reference."
    Aug 2015
    39
    Appreciate the replies.
    The Mini Magnetic base can get me by for a while, but I agree, I really want a more secure clamp.
    Maybe someday, a DRO, but a Clamp for a Dial Indicator would work best until.
    Thanks.
    How different are the bed edge dimensions, SB 9/10K vs 10L?
    Feb 2004
    peekskill, NY
    23,918
    4281
    You just make your own:
    That is actually set up on a 10L in the photos
  9. Likes Illinoyance, swatkins liked this post
  10. #8
    Aug 2015
    39
    Thanks. Looks good.
    I may consider making my own though it would be easier done with access to a working mill.
    DC
  11. #9
    Feb 2015
    Florida
    261
    45
    Quote Originally Posted by D_C View Post
    ...with access to a working mill.
    Amen to that. The hard-core method would be to use a hacksaw and a file!
  12. Likes Illinoyance, swatkins liked this post
  13. #10
    Sep 2010
    moscow,ohio
    5,579
    540
    1760
    Sometimes I wonder if anyone knows how to hacksaw and file anymore?
    Not a slam on the OP, but you can do it quite precisely if you know what you are doing.
    Hacksaws get a bad rap.
  14. #11
    Mar 2006
    New Jersey
    1,062
    11
    275
    If you have a lathe, you can mill small parts.
  15. #12
    Aug 2015
    39
    I bought the one sold on EBay for the Southbend 9 and 10K lathe.
    https://www.ebay.com/p/South-Bend-La...80e844fffba8cf
    The V-to-Bed bottom height dimension is about 0.100 taller on the 10L vs 10K, so the hinged clamp plate rests at a slight angle... and the machined-Flat on the 10L carriage is 3/8 inch farther out (see before photo below) so I mounted the dial indicator out 3/8 inch farther using a Bushing and longer socket cap screw.
    It works.
  16. #13
    Nov 2007
    marysville ohio
    9,020
    2565
    5976
    Why would you screw around with an indicator? Get a digital caliper and clamp it on. 6 - 8" of travel, simple to do, massively better I think.
  17. #14
    Aug 2015
    39
    Thanks.
    Yes, I have seen that too. There are a few good YouTube videos on how to make one from a cheap Harbor Freight digital vernier. I may well try that in the future, but for now, just wanted something ready-made.
    DC
