Drum switch wiring
Likes Likes:  0
Results 1 to 4 of 4
    Nov 2019
    Missouri
    Default Drum switch wiring
    I just acquired a 13" south end with a lesson 2hp single phase motor 230 v and it's drum switch had been removed. I have a Dayton 2x443 switch to install but I'm needing some help with wiring it up and was hoping somebody could offer some guidance and verify that is the correct switch it says on the motor that t5 and t8 are switched for reversing. I can't seem to post pictures now but will try later. Thank you for your help
    Mar 2011
    Geneva Illinois USA
    6,282
    2717
    2430
    T5 and T8 are the two leads that are normally interchanged for reversing.
    Tom
    Jul 2010
    Virginia, USA
    3,476
    87
    647
    Try again to post pics- particularly the wiring diagram of the motor and hopefully inside the switch cover, and the switch guts.
    allan
    Dec 2015
    24
    lesson-sp-dual-voltage.jpglesson-drum.jpg if the connection diagram on the name plate mounted on the side of the motor looks the sketch of in the pic. then the motor to switch connection diagram (in next pic ) will work for . good luck and be safe,Ray
