Fitting Taper Attachment - Babbitt Source
Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Dec 2016
    Michigan
    93
    12
    16
    Default Fitting Taper Attachment - Babbitt Source
    Iím in the process of moving a taper attachment from a 9Ē to a 10K South Bend. Since Iím certain that the taper bed height wonít be exactly the same as the last lathe, Iím planning on melting the babbitt out of the tie rod bracket and re-pouring it in place like what would be done with a new attachment. Does anyone know a good source of small quantities of babbitt I can use for this? The cheapest Iíve found so far is a babbitt paperweight on eBay for $20 shipped. Thanks!
    -Keith
    May 2012
    Indiana
    1,008
    182
    360
    I think McMaster Carr has it.
    Dec 2016
    Michigan
    93
    12
    16
    I looked there first. The smallest quantity they sell it in is 5 lbs for $50 pre shipping costs. Iím not trying to be cheap on this project, but I donít want to tie all that money up to use a couple ounces and have the rest sit on my shelf for the next 40 years. I may be able to collect the babbitt that I melt out, but my guess is that it wont all make it back in and Iíll be a little short. I could always make up the difference with something like JB weld, but Iíd like to leave it in a state that could be worked on again in the future without any surprises.
    Mar 2012
    Geilenkirchen, Germany
    2,469
    1465
    1243
    Quote Originally Posted by USNmechanic View Post
    I’m in the process of moving a taper attachment from a 9” to a 10K South Bend. Since I’m certain that the taper bed height won’t be exactly the same as the last lathe, I’m planning on melting the babbitt out of the tie rod bracket and re-pouring it in place like what would be done with a new attachment. Does anyone know a good source of small quantities of babbitt I can use for this? The cheapest I’ve found so far is a babbitt paperweight on eBay for $20 shipped. Thanks!
    -Keith
    Keith,
    I bought my 10K new in 1980 from SB with a TA. When it arrived it was not installed, I had to do it myself. It was a real pain in the ass. In your case you do not have to recast the drag link Babbitt. All you have to do is remelt it in place with the end nut slightly loose. I suspect you will have to drill and tap mounting holes in the bed casting as well. Do not dowel the TA in place. Snug up the mounting bolts lightly. Snug up the carriage clamp and adjust the TA parallel to the bed without the drag link in place. Then tighten the mounting bolts. Attach the drag link rod to the TA casting leaving the bed clamp loose. Lastly, remelt the bed clamp babbit and while melted, tighten the bed clamp. Then test for bind. You may have to do this exercise several times to get it right. Only then drill the bed casting for the TA dowels. The drag link rod bore in the clamp casting is much larger than the rod,so large flat washers are required on both ends of the bed clamp. They act as a Babbitt dam, so that nut must still be snug to prevent the melted Babbitt from leaking.
    Mar 2011
    Geneva Illinois USA
    6,341
    2747
    2468
    I had a similar problem with my heavy 10. Instead of redoing the babbit, I simply melted out the babbit and used large flat washers and let the clamp float. That way there is no stress on the TA. Works great!
    Tom
    Feb 2015
    Florida
    533
    117
    You could probably add some lead-free plumbing solder (TIN-ANTIMONY) to the babbitt that you remove from the clamp and recast with that.
    Dec 2016
    Michigan
    93
    12
    16
    Thanks for all the suggestions! I decided that I didnít want to melt it in place as it sounds like it was kind of a touchy operation and I only want to do this once. Before melting out the babbitt, I noticed that it looked like there was a sleeve between the tie rod and the babbitt. I figured that the washers pressed against this sleeve on each side to keep the babbitt from spilling out between the washers and shaft/threads. I found as I was melting the babbitt that this sleeve was babbitt as well. It seemed to have a slightly higher melting point than the other babbitt, but I ended up melting it completely and mixing it all together. I think this will actually help me, since I just made a sleeve out of some steel rod to take its place. Iím guessing with the new sleeve, Iíll have plenty of babbitt to fill the cavity now. Hopefully Iíll have time to finish it up tomorrow. Iím in no hurry though since Iím still waiting for the 0.2505 reamer for the dowel holes and a new cross slide nut to arrive.
    Feb 2015
    Florida
    533
    117
    You use putty to build a dam.
    Here is the taper attachment instructions (PART 1):
  9. Likes swells liked this post
  10. #9
    Feb 2015
    Florida
    533
    117
    Here is PART 2:
  11. Likes swells liked this post
  12. #10
    Jul 2003
    savannah, jaw-ja
    1,770
    1301
    426
    To answer the original question:
    Babbitt Bearing Alloys - RotoMetals
    Be sure to get the clay they sell for damming as well.
  13. #11
    Mar 2012
    Las Vegas
    653
    11
    64
    i have a chunk i will sell you.
    pm me for details
  14. #12
    Dec 2016
    Michigan
    93
    12
    16
    Thanks @SLK001 . Iíve been using this document to help with the fitting, but Iíll save yours too. http://www.wswells.com/data/howto/9_taper_Install.pdf
    @Rudd, thanks for the link! Iíll be saving that to my browser if I ever need some more in the future.
    @lectrician1, thanks! A PMs on its way.
    I figured I would try it with what I had just for the practice. My sleeve idea didnít work since the 7/16 hole ended up a little undersized and I donít have a boring bar or reamer that small right now. I donít have any putty either, but the two lapped washers did a good job keeping it in. I heated the babbit to about 650 F, and the bracket to around 350 F before pouring. It went pretty well, but ended up short. Iíll melt it out and do it again when I have more babbitt.
  15. #13
    Mar 2010
    Utah
    718
    58
    49
    I have some Babbitt you can have for postage..I will see if I can find it.{I know I have it just need to find it}
  16. #14
    Dec 2016
    Michigan
    93
    12
    16
    Thanks for the generous offer @packrat2, but Iíve already purchased some from @lectrician1.
  17. #15
    Apr 2010
    northeastern Pa, USA
    665
    130
    197
    For small jobs like this go to your local tire dealer and get used tire weights. They will be happy for you to take them.
  18. #16
    Dec 2016
    Michigan
    93
    12
    16
    I always assumed the tire weights were lead. I actually have several large ingots of lead left over from the previous home owner, but I wanted to stay away from using it for this instead of babbitt so the next owner of this attachment would know what theyíre working with.
  19. #17
    Mar 2010
    Utah
    718
    58
    49
    Quote Originally Posted by tommy1010 View Post
    The older wheel weights were a mix of lead and tin,{pistol shooters delight for casting bullets} but the newer ones have zinc in them which turns your melting pot to mush and makes casting pistol or rifle bullets impossible..
  20. #18
    Sep 2015
    Florida
    669
    5
    98
    Gotta wonder how this would work. It's a soft alloy I keep in the shop for chamber casts. Low melting point, dimensionally stable
    Smallest size is $15
    BROWNELLS CERROSAFE(R) CHAMBER CASTING ALLOY | Brownells
  21. #19
    Feb 2008
    newark DE USA
    1,204
    112
    You mentioned mixing two sources of babbitt that appeared to have different melting points.There are many varietys of this stuff and some of them are not compatible with one another.Two major varietys exist that are completely un-compatible.They are different alloys.Problems can result from mixing unknown babbits.
  22. #20
    Dec 2016
    Michigan
    93
    12
    16
    Thanks for all the advice! I was able to finish fitting the attachment tonight using the babbitt I purchased from lectrician1. It didnít go too bad, and Iím happy with the fit. The saddle feels very smooth traversing the length of the taper bed. Now all thatís left is to finish assembly and use it!
    My phone died from the cold in the shop, so I had to bring the pet in to get a picture.
