mcload
Hot Rolled
- Nov 5, 2007
- Houston, Texas
I have an old original Furnas RSB5 (circa 1958) drum switch for the GE 5KC43xxx single phase
motor that came on the lathe. After restoring the motor, I connected the Furnas controller
and the motor works fine in both directions. However, I knew a couple of the rear connection points
on the rotating body of the drum switch (not the spring pads) were paper thin, and that for all practical purposes, I would probably need to find a new drum switch for longevity reasons.
I have been through two new switches now, and neither have the correct connection points for
this 5-wire GE motor. I'm not at all surprised that nothing seems to be available except possibly the high-price used original Furnas controllers at auction. (No market for vintage switches).
So I just thought I send out an SOS to see if anyone has successfully found a "new" style controller for their old GE motor, and if so, the name and model number so I can order one.
(I've read thru several articles on PM on repairing these switches, and it all kinda sounds "iffy".)
I suspect I'll just have to use it until it quits at which point I'll have to replace the motor (or some new owner).
Thanks in advance; just floating a balloon.
PMc
View attachment 316162 View attachment 316163 View attachment 316164 View attachment 316165 View attachment 316166
PMc
