Grinder for HSS
Likes Likes:  0
Results 1 to 3 of 3
Thread: Grinder for HSS
    Apr 2009
    CA USA
    133
    13
    Default Grinder for HSS
    Readin the thread for the ToolBlock got me thinkin . I have the Grizzly Tool Grinder ,I also have several small bench grinders . What speed are we lookin for when sharpenin HSS ? I know some of the grinders for woodworkers are slower than the norm 1725 RPM . I have several good bench arbors & was thinkin of settin one or two up with different wheels, I can adjust the speed with different size pulleys . so if I'm usin a 1725 rpm motor what speed should I be lookin for ? I want to set one up with a white standard wheel on one side & a white cup on the other side .
    tks
    animal
    Virginia
    15,999
    7561
    10714
    Quote Originally Posted by animal12 View Post
    tks
    animal
    RPM wanted is relative to the diameter (hence also the SFM at the working face..) of the wheels meant to be used.
    Bad things happen when a wheel is run faster than its design rating. Time and wheel-life is wasted if run too slowly. The HSS itself isn't all that picky. Just do NOT "shock cool" a hot HSS tool with a water-cup dip. Plenty of published info on that.
    If one needs a large conventional wheel AND a smaller cup?
    Wiser to use two rather different grinders for them.
    Jan 2014
    North Carolina
    524
    20
    158
    There are some variable speed grinders on the market. I have one that uses 6" diameter wheels and I really like it for sharpening stuff because the reduced speed available cuts down on overheating the tool.
