Have I over chucked my south bend 9C?
Results 1 to 11 of 11
    Oct 2018
    New Jersey
    Default Have I over chucked my south bend 9C?
    Hi...
    I've lurked and gathered very helpful tips here for about a month since picking up a 1939 South Bend 9C. I'm brand new to machining and this is my first lathe. She spun up nicely at purchase but I have yet to set up in my studio as I'm building a sturdy butcher block style bench and acquiring some bits like a few change gears and a replacement chuck.
    The jaws on the 5" Union scroll chuck that came with the machine are quite worn but I thought no matter as I want a larger 4 jaw anyway. Having read elsewhere on this forum that 6" about right for these SB workshop lathes I picked up a very nice 6 1/2" on ebay. The point I neglected to consider is whether I should look for a light or a heavy duty chuck. The one I picked up turned out to be a heavy duty Burnerd that tops the scale at 25 lbs (about 4 times the 5" I want to replace)! With chuck mounted & spindle spun by hand everything feels buttery smooth and I would expect some extra weight could be useful to prevent problems like chatter but see my pictures... the chuck certainly looks large for the machine. I plan to face the backing plate before using any chuck I purchase (I learned that here) but my question is, would a chuck this heavy be at all useful or even safe for use on a South Bend 9?
    Original
    "New" chuck
    5" to 6.5"
    4" deep
    Opened to 7", ~1/2" clearance to bed
    Thanks - Mike
    Aug 2014
    AUSTRALIA
    495
    5
    128
    FWIW, I run an 8" 4 jaw on my 10L. It looks pretty darn big but does the job fine. I don't spin it too fast.
    I have a 6" 4 jaw as well, but the extra holding capacity on the 8" and the bore size means it is the one I normally reach for.
    Greg.
    Virginia
    26,235
    7561
    8258
    Quote Originally Posted by haus View Post
    Hi...
    Original
    "New" chuck
    5" to 6.5"
    4" deep
    Thanks - Mike
    Fifty, sixty years or so ago, a "premium" optioned SB shipped with a Cushman about half-way in between the two you show. Cushman about the same heft as the Pratt-Burnerd you have, but arguably stronger and better - they did fight over that - went onto spindles of Monarch 10EE and the like with a tad more heft under them and far greater power back of them.
    This one has eaten a chunk of scarce longitudinal daylight. That's about all.
    You won't run it long enough nor hard enough to much affect the bearings. Not unless you start making parts ten hours a day, every day. Which would be well short of "sane" on an SB 9 manual, anyway.
    "Safe", then, is up to you.
    That said, if the chuck is well-made?
    I'd be tempted to find a nicer lathe to put under it.... and have done.
    Mar 2012
    Geilenkirchen, Germany
    2,307
    1394
    1190
    No problem at all. I have run a 6" SB 4 Jaw and a 6" 3 Jaw SB chuck on my 10K since new (1980. The original SB 5" 3 jaw was no where near as good as the SB 6"......huge difference in everyway.
    Sep 2010
    Oklahoma City, OK
    4,193
    721
    1768
    The bearings shouldn't care, I'd be more concerned with the extra bed length and horsepower it's eating. On the other hand, it could be pushing you toward a better spot on the ways?
    Apr 2007
    Scotts Valley, CA
    697
    42
    64
    Quote Originally Posted by steve-l View Post
    Agree. I run both 6-1/4" and 5" 3 jaw Bison chucks on my 10k - the 6 is a heavy sucker but no problems. The 6" Bison 4 jaw I have is WAY lighter than the 3 jaw.
    Nov 2008
    Madera county california usa
    2,401
    21
    594
    Mass and newton...
    Flywheel effect.
    The larger rotating mass will consume a bit more power to startup so motor may complain when starting in higher speeds.
    Also note this larger rotating mass will mean less margin for error if you get something where it does not belong.
    Careful management of jaw placement is critical as you have not to much overall movement so reversing them may get old.
    ALWAYS rotate by hand to insure a jaw does not tag the ways or carriage.
  8. Likes SteveM, MetalCarnage liked this post
  9. #8
    Feb 2008
    newark DE USA
    1,174
    108
    My 9" workshop lathe came with a 7 1/2" 3jaw chuck fastened to its face plate. Im not sure what the previous owner was doing with that setup.I never used it because I got a 4" 3jaw that is very handy on that lathe. Some day I will make a plate to use that thing on my 13" Regal,it opens really wide.Point is someone had a use for that chuck on that little lathe.
  10. #9
    Jan 2009
    Tennessee
    1,205
    124
    As others have said you should not have any problems using that chuck. just pay attention to what you are doing. On the other hand putting it on and removing It, Might be a challenge. You may smash a few fingers in the process. I suggest putting a good 3/4 wooden dowel well into the spindle. Leave enough on either side to use as handles. Also put a piece of wood across the bed to protect it. That thing is too heavy to take chances with.
    Stay safe and have fun.
    Joe.
  11. Likes SteveM liked this post
  12. #10
    Oct 2009
    Louisville, KY, USA
    926
    213
    204
    I occasionally use some heavy 8" chucks on my 10L, primarily for the larger through hole. It takes noticeably longer to spin up, but no other issues to date.
    With the chuck mounted on the spindle, I traced its outside diameter onto a 2x4 laid across the ways, then cut that out to create a rest that can be used to slide the chuck onto the spindle and to prevent the chuck falling on the ways or my hand during removal.
    I got the idea from someone on this forum, but it was years ago and I've forgotten who to credit.
  13. Likes Greg Menke liked this post
  14. #11
    Dec 2008
    North Carolina
    675
    200
    158
    Nice looking chuck. A good brand with a reputation of well made. Just don't over extend the jaws and clip the bed or carriage and you will be golden.
    Vlad
