colinag
- Apr 1, 2009
- Woodstock On Canada
Hello; I have a mid 50s? Heavy 10. I've searched but had no luck with this problem. When in power feed at any speed I get a regular pattern on the piece being turned in time with the rotation of the lead screw. It is not one for one but reduced as though it's through the worm and clutch but in a regular pattern . I have rebuilt (replaced bearings) the quick change gearbox and found no problem with it. The lead screw is straight and the tail stock end bearing is good. I have stripped and reassembled the apron and can find no problem yet on re assembly of the lathe can feel a tight spot when turning the quick change input by hand. this is about every 20th or so revolution of the lead screw with power feed engaged but not with out. I am using non detergent 30 oil in the apron I'm at a loss here. Thanks for reading through my 1st world problem. Can you offer any advice? Thanks Colin
