FTF Engineering
Hot Rolled
- Oct 30, 2003
- Philadelphia, PA
Are the different base configurations used on the heavy 10's interchangeable? By that, I mean, can you move the lathe portion of any heavy 10 say, from a cabinet onto a pedestal, or vice-versa?
Are they all interchangeable? All the holes line up and all that?
Is one version preferred over another for any reason other than aesthetics?
This one, which I believe is referred to as "The Pedestal" base:
And a couple of different cabinet mounts.
The first which I believe is the oldest and is referred to as "The Bent Leg" cabinet
And this one which I believe is the newest design. I don't know if it's earned a pet name.
I also found this one, but I'm not sure if it's shop made or factory supplied:
Any others as well?
Any others as well?
