Heavy 10 serpentine belt?? - Page 2
Page 2 of 8 FirstFirst 1234 ... LastLast
Results 21 to 40 of 157
  1. #21
    Oct 2006
    Minneapolis Minnesota
    126
    Post
    hi Jim
    I just used my bench grinder with a coarse wheel, it didn't take that long, had great control of the depth, etc. and didn't stink up the shop with the smell of burning rubber, thats always a bonus! as you can tell by the picture I went to just exposing the reinforcement and stopped right there not to weaken the belt. I think the more overlap the better, so mine is 8 inchs of the reinforced area then one inch of taper on each end. I was going to use the different types of rubber glue but I needed to get something that dried quickly at the time. we have some of the tire patch glue that you can burn and gets real sticky, thats going to be my next victom in this process. really let us know how the weather strip adheasive works we have a bunch at our shop but I would wait 24 hours before putting tension on it. good luck Jim!
    Tony
    [ 02-10-2007, 10:02 PM: Message edited by: 540i928 ]
  2. #22
    Feb 2004
    peekskill, NY
    23,912
    4279
    Post
    I think I'm starting to understand the comments
    about the cords.
    The belts are manufactured with the cords at
    a precise depth, so one can use them as an
    'end point detection' which is what they call
    the problem in silicon wafer polishing terms.
    Basically, how do you know how deep to go?
    You go as deep as the cords show up, and then
    stop.
    Will try this tonight.
    Jim
  3. #23
    Oct 2006
    126
    Post
    perfect!
  4. #24
    Sep 2005
    Indiana, USA
    2,868
    70
    Post
    Jim, I agree. It makes sense that you would want most of the cords intact on both ends of the lap joint, since the cords are what give the belt its tensile strength. Otherwise, you'd have a serious weak spot at the glue joint.
    Another adhesive that has worked for this application is Loctite's #85265 "Super Glue for All Plastics".
    Paula
    [ 02-10-2007, 11:45 PM: Message edited by: Paula ]
  5. #25
    Feb 2004
    peekskill, NY
    23,912
    4279
    Post
    Well, I must say the bench grinder make short
    work of the belt material. And it was tolerably
    easy to stop at the cords, on both sides.
    The trim adhesive may or may not be doing the
    job - I expected it to set up rapidly - but it
    was gooey for five minutes at least. I finaly
    grabbed a clamp to keep it from coming apart,
    and went and got my leather belt gluing jig
    (shallow one inch wide grooves in aluminum
    angle iron) and clamped it up the way I do
    leather belts. I'll give it the "all night long
    in the dark basement" treatment and report on the
    outcome in the morning.
    I have enough for another try if it doesn't work,
    even if the glue won't come off.
    I would say that the nitrile gloves were a
    must-have here. Aside from the chemical issue,
    that stuff was as sticky as baby $hit on a wool
    blanket!
    Jim
  6. #26
    Jan 2007
    Albuquerque, NM
    23
    Post
    I'd say there is an oportunity for some money to be made here. I don't trust myself grinding the belt. I just know I'd bugger up the $20.00 belt. Now if some sharp cookie could came up with a jig to grind the belt?? I think I'd buy it!
  7. #27
    Feb 2004
    peekskill, NY
    23,912
    4279
    Post
    Preliminary results look good. I was pretty
    apprensive that the glue would not set up, it
    was so gooey. But it set up quite hard, but
    still somewhat flexible. My other worry (that
    it would bond the belt to the aluminum angle
    I was using to align things with) did not come
    to pass. I had wiped most of the stuff off the
    exterior.
    The belt sure does grip more than the leather
    I was using. On the highest range, the small
    motor I have is barely able to get out of start
    mode, whereas before there was enough slip
    in the drive to let this happen right away.
    At this point I have a leather belt from motor
    to countershaft, and the gates belt between the
    c/shaft and the headstock. I am positive if I
    replaced the motor one as well, the motor would
    simply not go into run mode at all.
    Today I will pick up another belt and some more
    adhesive, with the 10L in mind.
    Jim
  8. #28
    Oct 2001
    Lewes, DE.
    1,419
    Post
    Hi There,
    If you wax the aluminum angle before hand, you
    shouldn't have any problems.
    Good Luck!
    -Blue Chips-
    Webb
  9. #29
    Oct 2006
    126
    Post
    sounds like your doing great so far! glueing it together is a really a messy operation, see I wasn't joking about the gloves. any thinner or carb cleaner will clean up the mess, but watch around your belt. I have a 1/2 horse on my nine and a 1 h.p. 3 phase on my heavy 10 now I can use all the power and I don't have to stop to reset the belt on the pulley's. seemed like every time I got into a good cut I would have the belt go off the pulley. I haven't had one single incident but now I can actually break tooling and thats my fault and can deal with that lets hear the progress reports and how its working out for you.
    Tony
  10. #30
    Feb 2004
    peekskill, NY
    23,912
    4279
    Post
    Wax, or I think in my case I was saved by
    the fact I store the fixtures in the cabinet
    of my 10L, and they seem to pick up a bit
    of oil. So while they stuck a bit, I was
    able to get them loose without too much trouble.
    My other problem was the belt I bought was
    24 mm (which gates translates into 15/16 which
    allowed a mm of side play, so the glue-up was
    a teeny bit offset.
    The next belt is 25 mm so that should be less
    of a problem. I may try to scare up some
    teflon-loaded delrin to make a new fixture from.
    I forgot to add btw that I decided (seeing as
    this was really only a test) to do the lap
    joint shorter than suggested. On the one I did,
    it's only about 1.5 inches long. The trim
    adhesive seems to work very well.
    Jim
  11. Likes Daniel3105 liked this post
  12. #31
    Aug 2004
    So. Cal.
    1,488
    Post
    Wow, great write up guys.
    Thanks Tony, I'm thinkin an autoparts store run is in order. JRouche
  13. #32
    Feb 2004
    peekskill, NY
    23,912
    4279
    Post
    Report on weatherstripping adhesive:
    Not too good. While it continues to work
    well on the cataract bench lathe, the splice
    I put on the 10L lasted about 30 seconds on
    the lowest speed, whereupon I shifted it to
    the middle step. It failed about 10 seconds
    after that.
    Inspection of the break revealed the adhesive
    seemed not to have bonded to the exposed cord
    layers at all. I think on this one, it was
    only the ends that were really bonded, where
    there was rubber-to-rubber contact.
    Rather than try to re-work the belt to give
    contact area without cords (it did wind up a
    bit on the long side, so this could be done)
    I chose for the fun of it to try the second
    choice adhesive, permatex superglue gell.
    I cleaned the surfaces with a bit of alcohol
    and found that the superglue does indeed tack
    up pretty fast, even before I could get the
    clamp fixture on it.
    I did clamp it up after that, and am waiting for
    some time before trying it out. If it lets loose
    I suppose I could try the leather belt cement,
    or maybe some other kind of contact cement.
    The other interesting result that occured when
    I was trying to figure out which way the splice
    should run, was that I had closely inspected
    the existing leather belt on the bench lathe.
    I alway remind myself which way those splices
    are supposed to run because the factory splices
    go in one direction, and they say on the belt
    which way that's supposed to be. So I always
    replicate that.
    But when I went to set it up on the 10L the
    other night, I realized that I had made the
    splice on the existing leather belt
    the wrong way around. Or so I thought.
    Close inspection revealed I had made the splice
    the right way. But mounted the belt inside out,
    with the smooth side *away* from the pulley.
    Grr. That may account for why the belt's always
    been a bit "slipply" over the years.
    I was however able to flip it around, so it's
    right side out now.
    Jim
  14. #33
    Oct 2006
    126
    Post
    Jim, I never like weather strip adheasive we run a vehicle building and repair business and use that stuff all the time and cant get it to bond well with the static glueing of weather strip material to a vehicle. I really feel the my next experiment is going to be the flamable tire patch glue. there is some good atributes it has with flexing and holding power, still after 30 years of doing this I yet to see a patch that has come off if done properly. my belt on the heavy 10 is still working perfect with the glue for all plastics, Iam really suprised at the holding power and the flexabilty of this product so far.
    Tony
  15. #34
    Aug 2004
    So. Cal.
    1,488
    Post
    So solly, abit straying here,,, But...
    Is the weather strip glue you are using a basic rubber cement?
    If so you have to make sure you glue both surfaces completely and let them thoroughly dry before making the joint. After using a good solvent (acetone) on the mating surfaces.
    And when you go to make the joint make sure you are certain where you want it because it wont slip around for adjustment.
    I have always had good performance with rubber adhesive when used correctly. A good one is Gasgacinch made by Edelbrock. JRouche
    http://edelbrock.carshopinc.com/prod..._id/20906/9300
  16. #35
    Sep 2005
    Indiana, USA
    2,868
    70
    Post
    Just throwing a comment in here...
    Long term success with Barge cement, weatherstrip glue, rubber cement, etc. doesen't seem likely to me. I think the trick to preserving the tensile strength of the joint is to make sure a sufficient length of the cord from each end is in contact in the joint. And since the cords are usually polyester (or similar) you really need to use a more "high-tech" type of glue to get a strong bond, like the glue-for-all-plastics (or some other type of catalyzed, or cyanoacrylate adhesive).
    I'm not speaking from any direct experience here, but that's how it seems to me.
    Paula
  17. #36
    Jul 2003
    Los Angeles, California
    616
    6
    Post
    Ok, I'm really stretching my memory banks here, but I believe if you search the archives, Evan posted that he used a Loctite brand adhesive touted to glue any and all plastics, on his spliced serpentine belt. He reported it worked great.
    Jeff
  18. #37
    Jan 2002
    grand haven,mi., USA
    337
    6
    Post
    Years ago when I got my Heavy Ten I had to cut the special belt that came with it in order to remove the headstock to send the bed to SB to grind it. On return the regluing the original belt needed special glue so having several serpentine belts from cars that I had replaced with new belts, I decided to try one. I cut the belt off square, drilled small holes in the grove bottoms and laced it together with small diameter stainless steel wire. Seems to work OK , but has a 1/8" gap due to streatching.While I have not used it too much because of health problems what I tried works OK.
    If this fails or has other problems I will try the glued system.
    Walt
  19. #38
    Feb 2004
    peekskill, NY
    23,912
    4279
    Post
    I tried but did not find the Dr. Bonder
    plastic adhesive (permatex) locally. Obviously
    I will keep on searching for this.
    However the cyanoacrylate gell glue (also
    permatex) that I put on last night seems to
    be holding up pretty well. I even chucked
    up some steel and began taking some pretty
    serious cuts on it, much faster stock removal
    than the leather belt. Not quite a gear head
    lathe but a good deal better.
    It is apparent that these belts need a lot
    less tension to deliver power than the leather
    ones.
    My next quandry: should I cut off the leather
    one, or leave it on for now. At the moment it
    is resting on the smallest step on top, and
    pulled out of the way onto the shaft at the
    extreme left at the bottom, so it is idling.
    I could always put a new leather one on if need
    be, I've got the belting and glue....
    Jim
  20. #39
    Oct 2006
    126
    Post
    I had some time today ( that in its self is an oddity!) and cut up a bunch of belts we had sitting around. ground them down and glued them back together with everything we had in the shop. reports comming soon.
    Tony
  21. #40
    Sep 2006
    Spotsylvania, VA
    660
    5
    Post
    The ice storm here last night kept me home today, so with a little time on my hands I thought I would try to adapt an old serpentine belt to my 405. This was somewhat unplanned and I didn't have any suitable glue, but I have a Clipper Belt Lacer so I figured I could rig something up. As it turned out, I think it worked too well. When I started the motor, it jerked the countershaft pulley loose from its shaft. I re-tightened the allen screw and tried again, but the pulley came loose even before the late came up to speed. Is that allen screw all that holds the pulley in place? I'd have thought there would at least be a flat spot on the shaft to tighten the screw against.
    Tom
