Heavy 10 serpentine belt?? - Page 9
Page 9 of 9 FirstFirst ... 789
Results 161 to 163 of 163
  1. #161
    Nov 2017
    248
    163
    155
    I see that SG is available in 1 oz tube from True Value and Lowe's for under $4.
    I first tried it on the smooth, unground surface of the belt back. It peeled easily. Very different matter with surfaces that have been ground. Treadmill belt will probably provided plenty of grip. How thick is it and are you going to grind a lap?
  2. #162
    Feb 2015
    Florida
    334
    57
    Quote Originally Posted by MrWhoopee View Post
    The TM belt is approximately 0.1" thick and I WILL grind about a 3" lap on both parts. Walmart has a 3.7oz tube sold by Zoro for about $5.5 with free delivery - can't beat that!
  3. #163
    Nov 2017
    248
    163
    155
    Quote Originally Posted by SLK001 View Post
    A 3 in. lap will probably be more than enough. I have been trying to separate the 1 in. lap on my test piece and have failed, even trying to pry it apart with a small screwdriver. Just be careful not to compromise the reinforcing fibers, that's what caused the failure of my first belt. I'm considering using a butt joint with a separate piece of belt to overlap the joint.
