While attempting to reduce the lost motion in the crossfeed, I noticed movement at the rear thrust bearing. I removed the lock-nuts and pulled off the "bearing" and two washers/spacers. I say bearing, but what I found inside the bearing cover was just a thick washer with a 5/16 id.
Can someone tell me what type of bearing was supposed to be there? I've been looking for ball or needle roller thrust bearings, but have found nothing that will fit (3/8 id x 3/4 od) Oilite bronze thrust washers are available, but I wanted to find out how it was supposed to be. The parts manual is no help other than telling me there should be a bearing and "collar".
