Help on a 13" - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Thread: Help on a 13"
  1. #21
    Jun 2019
    UNITED KINGDOM
    12
    Thanks all, I tried out this solution but it needs some work to make it fit, the issue is that banjo fouls the gear on the feed reverser. I can mill 1/2" ARC out of the banjo and that should allow the gears to mesh again. Pictures attached.
    I also tried using the 48T as the stud and the 24T as the QCGB drive , it's closer but still fouls the banjo in the same place.
    Anyone have any other idea's?
  2. #22
    Sep 2010
    moscow,ohio
    6,394
    653
    2132
    hmmm, yes, a logistics problem there.
    the factory metric kit was all 16DP so it would all fit.
    There should be no issue with GPs suggestion tho? 24stud to 80idler to 48lead?
  3. #23
    Jun 2019
    UNITED KINGDOM
    12
    Quote Originally Posted by Westie View Post
    Just got back from hols, so finished this project off. The final solution was to shorten the banjo, I cut about 2.5" off, then made a small block to close of the open arms and fixed it with a set screw. The gear-train all links up fine now whether using the 64T or the 48T gear driving the QCGB, as described by Genepool
    The only minor inconvenience is that I can't close the gear cover with the 48T in place as the 63/80 compound gear sits much higher.
    Thanks for all your help, I'd have struggled without it!
