Mr Bridgeport
Stainless
- Nov 27, 2002
- Burlington, NJ
It's been quite a few years since I've posted on this forum but I'm back.
Anyway, today I helped my buddy bring home a SB lathe. Looks to be a 16" swing and the plates says 6' bed. Kind of weird, looks to only swing about 30" or so between centers. Guess that's the overall bed length. Useless specification.
I figured there would be a serial number/Cat No chart in the stickys but nothing there.
Bed SN is 13266HKX
Cat No CL81140
This uses a two speed Reliance Duty Master AC motor and has two sets of Allen Bradley push button switches mounted down by the tailstock. Each switch box has forward/reverse/stop.
Motor specs are as follows.
HP RPM Voltage Amperage
3 1745 230 8.8
1.5 860 230 7.6
So it looks to be wired as a 230VAC motor with no other options. There are two sets of forward reverse contactors on the headstock pedistal on the back.
He has a 5HP rotary phase converter that I gave him to use on his Bridgeport and Marvel roll in saw. When I powered the lathe up I could hear contactors pulling in but the motor would not energize. I know the previous owner and he told me that there was an issue in the contacter box as it was hit and would not work anymore.
There is very minor damage to one of the contactors. I'll probably have to change that one out.
I'd love to find a wiring schematic for this lathe. Does anyone have the same setup?
Thank you
Mr Bridgeport
Bed SN is 13266HKX
Cat No CL81140
3 1745 230 8.8
1.5 860 230 7.6
Thank you
Mr Bridgeport
