Help with SB 117E
Results 1 to 14 of 14
    Sep 2019
    Default Help with SB 117E
    Hello all,
    I recently picked up this south bend at an auction for the low low price of $100. I have next to no machining experience so I thought I’d ask here.
    To start, there’s no plug on the lathe. I do somewhat know the person who put it in the auction and he had just got a new machine, so I’m assuming he kept the plug for the new one. I’m wondering how to find out if this lathe is 3 phase or not. I can’t seem to find the serial number on the lathe anywhere. There’s just a tag that says: 16” swing, 8’ length of bed, and catalog 117E.
    I really don’t know anything about this machine so any help would be appreciated. My shop is only setup for single phase, so any help in that department would be great too. Thanks in advance.
    Oct 2012
    central Pa., U.S.A.
    317
    130
    71
    Check the motor tag. Will tell manufacturer (Westinghouse,Louis Allis,Century, etc.),Horsepower,Phase(single or 3)and voltage(220/440) and single or two speed. I doubt someone would have put a 120 volt motor on. If the motor is 3 phase, you have several options to power it up. A static phase converter, a rotary phase converter, or a VFD(variable frequency drive), all different prices to fit your need. If you can contact the previous owner, that's certainly an option to find out the electrical hookup needs. PB
    Jan 2019
    North Carolina
    228
    26
    39
    I can’t help you with the machine, on mobile and just don’t feel like going through all of that.
    As for the 3 phase debacle.. there usually wouldn’t be a plug on the machine regardless of 3 phase or not. You’d preferably always hardwire machinery to a service disconnect instead of a plug. There’s no information on the lathe specifically that would tell you if it’s 3 phase. Just take a look at the name plate on the motor and it will tell you. As for the serial number, it’s stamped on the bed operator side at the tailstock end. Should be on the flat closest to you a few inches from the end.
    Mar 2010
    Utah
    703
    53
    43
    Look at where the power goes into the lathe, if its three phase it should have a three phase disconnect box or a three phase motor starter.
    Not sure how old a 117E lathe would be{maybe too old for a magnetic motor starter}..
    Jul 2004
    Houston, TX USA
    29,641
    Still for sale in catalog 100-F August of 1946
  6. Likes DrHook liked this post
    Sep 2016
    Missouri
    781
    668
    221
    Here are a couple publications submitted by Mike Lutz and Dennis Black to vintagemachinery.org
    .South Bend Lathe Works - Publication Reprints - South Bend Lathes Catalog 100B | VintageMachinery.org
    South Bend Lathe Works - Publication Reprints - 1947 South Bend Precision Lathes | VintageMachinery.org
    Both catalogs should cover your lathe series.
    'More great S.B. resources.
    The SBL Workshop
    My 1942 117e has a magnetic starter
    I couldn't find catalog 100f that John speaks of.
    Jul 2004
    Houston, TX USA
    29,641
    Might be in these four pages
    The SBL Workshop - Catalog Index
  9. #8
    Sep 2016
    Missouri
    781
    668
    221
    If he returns with a serial number we could get him narrowed down.
    He should be overwhelmed with reading material for a day or two.
    His first three phase could send him here. https://www.practicalmachinist.com/v...rters-and-vfd/
  10. #9
    Sep 2019
    Thank you guys for all of the replies, I have a lot of reading up to do. Sorry I've been out the last couple of days. I combed over the machine this evening and was able to find the serial number (it was damn near rubbed all the way off) and a tag on the motor. I also took a couple pictures of the on/off/reverse switch box if I can figure out how to post them.
    Lathe serial # is 75230
    From what I could read on the motor:
    Type CSP Induction
    HP: 2 Frame: 221
    60 cycles 50 cycles
    220/440 volt 220/440 volt
    5.8/2.9 amp/turn ??/3.2 amp/turn
    1735 rpm 1445 rpm
    40 c. rise cont. 50 c. rise cont
    Class: 1
    Style: 1442151
    Serial: 6412
    I wasn't able to decipher the manufacturer of the motor
    The plate on the motor was difficult to read so some of those numbers may be off. There are also a total of 12 terminals on the on/off/rev switch.
    Edit to add: Thanks again for all of the reading material. My father-in-law has been a machinist for a long time and is planning on coming to visit here in the next few weeks, so I'm hoping to have the lathe up and running by then so he can show me the works.
  11. #10
    Sep 2016
    Missouri
    781
    668
    221
    Your lathe was made in 1937.
    Go down the list of serial numbers until you see where yours would fall in between higher and lower numbers.
    South Bend Lathe Serial Numbers
    When you can post pictures of your lathe.
  12. #11
    Sep 2019
    Trying to figure out how to post pictures.
  13. #12
    Jul 2004
    Houston, TX USA
    29,641
    Good chance the rotary switch is taking the place of the mag starter that came later
    I have a rotary switch that was completely used up starting and reversing a 15 HP motor - weighs about 30 lbs
  14. #13
    Sep 2016
    Missouri
    781
    668
    221
    Back in the days of those big switches you could order a set of contacts and replace them. I use to set up machines that we did a lot of jogging during setup. When a relay started chattering we replaced the contacts. Those days are gone. There are still some replacements contacts around but it's not the norm to rebuild a switch. Don't file them flat. When the silver is gone they start welding and sticking.
  15. #14
    Oct 2019
    Washington
    Where did you find that s# ? Looks alot like my 117E that I've determined is a 1942 via sw wells s# database..mine has the original motor that's 3phase I used an old rotary phase converter to run it in my home shop?
