How to fix worn pinion bore in apron? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21
    Aug 2021
    Washington
    24
    Ha! That's original and crazy. Wonder if it worked at high rpm?
  2. #22
    Jun 2004
    825
    770
    175
    Quote Originally Posted by Doan View Post
    yup its right up there with the hydraulic distributor that was on some of the tucker cars that operated the valves
  3. #23
    Aug 2021
    Washington
    24
    Thought I would post a follow up.
    My solution was to ream the apron oversize and turn an oversize shaft on the lathe. Reaming the apron. for some reason the picture is upside down.
    It turns out that the heavy 10 pinion and the 9" pinion are the same(thanks Latheman) except that the 9" version is pinned to the shaft and has a 5/8" bore.
    Turn the shaft down to the fit the oversize apron. Turn one end of the shaft down to 5/8" creating a step in the shaft. Then press on the pinion gear - it is an interference fit- and cut off the extra.
  4. Likes mattthemuppet liked this post
  5. #24
    Aug 2021
    Washington
    24
    Reached the 5 picture limit...
    Locate the gear on the shaft and drill a hole for the pin. Fortunately I had the correct reamer for the taper pin.
    The closer fitting pinion meant a shim had to be removed from under the rack, but once this was done there is very little play in the handwheel and the carriage travels smoothly.
    Last edited by Doan; 09-15-2021 at 05:02 PM. Reason: thumbnail pictures not showing
