Frank R
Stainless
- Dec 18, 2009
- Dearborn, Michigan
I have a Heavy 10 that I picked up a few years ago and only use occasionally. It currently has a 3-jaw chuck on it as well as the hand lever collet closer on the left end.
Last night I needed to put a piece of stock through the head stock but it bumped into the right end of the collet closer. I then attempted to remove the assembly from the left end but it would not come out. The assembly spins freely but it will not pull out. I am thinking there is some kind of set screw or the like. BTW: the bracket that connects the hand lever (part 32) to the machine is broken but that should not play a part.
Any help would be appreciated.
