Ideas on headstock repair - Help please
Page 1 of 2 12 LastLast
Results 1 to 20 of 36
    Oct 2019
    CANADA
    Quebec
    16
    12
    Default Ideas on headstock repair - Help please
    So I have a Southbend 9a that has badly scored head stock, mostly on the front bore. I found a used unit that is better (but not perfect) for the meantime but I would like to repair mine. Two choices - send it out for repair or fix it myself. I have spoke to a couple local machine shops but the prices to repair "properly" are coming in around 6 to 8 hours labour, although I respect their expertise in the subject, the repair is more then the lathe is worth. It seems like the different size bores poses a problem to bore strait without spinning the headstock around thus losing the zeroing.
    It would seem logical to oversize the bores then build up my spindle to match.
    How would you guys go about it repairing it?
    If I were to try my hand on repairing it, it's really hard to explain, but I was thinking of using some sort of boring bar in my now functioning lathe (used parts) then setting the damaged headstock in front (on the same bed rails) then slowly pushing the damaged headstock using the apron or tail stock to feed.
    Hope that was clear... please bare with me I am a hobbiest, and I dont have a milling machine
    Thanks for any ideas, fix it myself or what to ask for from the pros
    Thanks in advance
    Sent from my SM-T590 using Tapatalk
    Apr 2010
    northeastern Pa, USA
    729
    148
    221
    Pay the postage and I will give you a nice headstock.
  3. Likes Rouke liked this post
    Oct 2019
    CANADA
    Quebec
    16
    12
    Quote Originally Posted by tommy1010 View Post
    I sent you a private message.
    Dec 2012
    AUSTRALIA
    2,838
    12
    916
    OP obviously has had anything posted from the US lately.
    Sep 2002
    Lawrenceville GA USA
    6,282
    858
    1383
    The OP appears to have sorted this out, good luck with your lathe. But just in case he still wants to make a go of it I will move this to the South Bend forum so they can advise the best way to proceed.
    Charles
    Oct 2019
    CANADA
    Quebec
    16
    12
    Re-opened thred !
    Would love to get some ideas please
    Regards
    Feb 2013
    North Carolina
    432
    548
    168
    Not sure how plausible his story was but long ago I met a guy who claimed to bore out these headstocks for needle bearings.
  9. #8
    Sep 2010
    moscow,ohio
    6,284
    643
    2074
    seen worse.
    before anything just remove any burrs or high spots.....remove the adhered cast iron deposits from the spindle.
    put it back together, properly lubed with the correct clearances....run it and make stuff.
    as long the spindle(the rotating element) is OK oil will fill those grooves and there wont be any metal to metal contact....the spindle "floats" on a film of oil during operation.
    ps...thats im guessing is a VERY early headstock for a true 9A....the capillary oiler well is square and it where the shims slip in is slotted for a strip of felt on the inside.
    i am assuming it has side oilers??
    another pic of the front would be good.
  10. Likes Rudd, garyphansen liked this post
  11. #9
    Feb 2015
    Florida
    670
    168
    Algeria... that's in Alabama, right?
  12. #10
    Oct 2019
    CANADA
    Quebec
    16
    12
    Quote Originally Posted by cranium View Post
    Well one machine shop I spoke with suggested installing phosphorus bronze bushings but I would lose the ability to fine tune my clearance...
    Quote Originally Posted by iwananew10K View Post
    seen worse.
    This is very bad, even with the two bolts torqued down to the point I thought I might crack the headstock - it still had up and down play. My front bore is horribly oval.
    This has front oilers.... I will post a pick tomorrow
    What year are you thinking this lathe is? Where would I find a date code?
    Quote Originally Posted by SLK001 View Post
    Sorry I don't know what you are talking about.
    How would you guys go about boring the headstock, if that had to be done?
  13. #11
    Mar 2002
    Oregon
    263
    35
    Quote Originally Posted by MecGen View Post
    Depending on the design of your other lathe's carriage, you can set up the headstock on the carriage and line bore it using a custom made boring bar. You can see some videos of line boring on a lathe on Keith Fenner's YouTube channel.
    Also, there is a post here on PM by the late Forrest Addy that had links to some of Fenner's videos showing how it is done.
    How the pros do it: line-boring on the lathe
  14. #12
    Nov 2017
    338
    228
    224
    You were maybe thinking of Angola, and it's in Louisiana.
  15. Likes Rudd liked this post
  16. #13
    Sep 2010
    moscow,ohio
    6,284
    643
    2074
    used to be a glitch in the forum that would default to Algeria when someone put their location in as Alberta(Canada) i think.
    you can get year of maunfacture from the serial number on the bed.
  17. Likes MecGen liked this post
  18. #14
    Oct 2019
    CANADA
    Quebec
    16
    12
    Quote Originally Posted by Don Kinzer View Post
    Yes that's what I was thinking about doing, except with my headstock the journals (bores) are two different sizes. I would have to adjust my cutters in between the two journals
    Thanks for posting those videos, I skimmed over them and got the just, but I will go back when I have more time.
    Thanks for replying
  19. #15
    Mar 2002
    Oregon
    263
    35
    [...] my headstock the journals (bores) are two different sizes. I would have to adjust my cutters in between the two journals
    I would think that you would bore one and then with the same setup bore the second one. It's still line boring even though there are different bore sizes. The technique refers to boring two or more holes with the same center location.
    Depending on the size of the lathe you'll be using for the boring operation, you may need to make a boring bar with multiple cutter locations.
  20. #16
    Oct 2019
    CANADA
    Quebec
    16
    12
    Hello Don
    That exactly what I was thinking, making a double cutter boring bar. Two out of 4 shops I went to, this seemed to be a problem for them... well equipped shops at that, so I thought I would ask here. One shop said he would plane the base, plane the side then make a custom jig/holder just so he could do one hole at a time. Like I said above, I hobby with my lathe (auto mechanic) so I was thinking this was getting way too complicated or maybe I was not understanding something in the set up. I respect tradesman and the job they do, so maybe I didn't question their technique enough.
  21. #17
    Virginia
    30,529
    7561
    9532
    Nah. What you need to "question", given you are an expert craftsman yerself, and have some fair idea as to what your own time bills-out at, "fully burdened", is why you'd invest even MORE of your time (learning curve thing) than they would need.
    Not that it cannot be done.
    But that it is akin to putting more time, parts, and effort into repar of a dirt-common motorcar than THAT is "worth". You might DO this for a vintage Cobra or Pierce-Arrow.
    But not for a fifteen year old Camry or Civic.
    Faster and CHEAPER to part-out what you have.
    And go find another lathe that doesn't NEED so much work to be PUT "to work".
    Life is too DAMNED short to repair and refill Bic lighters or warsh-out and re-roll used condoms just because you are clever enough to figure out "how"... and stubborn enough to actually DO it.
  22. #18
    Oct 2019
    CANADA
    Quebec
    16
    12
    Point taken
    Oh I know that this lathe is not worth the cost of the repairs needed, if I pay a shop. I have a bad habit of putting wwwaaaaaayyyyy to much time/money in my muscle cars that I will never see again.
    That is why I have found some used used parts so I can get this lathe working. I like antiques and especially antique lathes, so probably I will put more time and money into this one, more then it's worth. It's a sickness
    Cheers
  23. #19
    Virginia
    30,529
    7561
    9532
    Point taken
    Cheers
    Aye. About 60 thousand dollars worth of "sickness" when your "Old Iron" is NOT "South Bend".
    THIS .. is what happens when a person gets too OLD for sexual masturbation, then?
    Nah. Don't ANYBODY answer that!
  24. Likes MecGen liked this post
  25. #20
    Oct 2019
    CANADA
    Quebec
    16
    12
    I am old but I am not touching this
