Identify "extra" gears
Results 1 to 14 of 14
    Apr 2004
    Illinois
    178
    20
    Default Identify "extra" gears
    I purchased a 9" South Bend which included two "extra" gears. They do NOT fit on this lathe. I'm hoping someone can identify which machine these belong on.
    The large gear:
    5.5" dia.
    64 teeth, 3/4" wide
    3/4" bore with 1/8" keyway
    Small gear:
    2.320 dia.
    26 teeth, 5/8" wide
    5/8" bore
    Feb 2015
    Florida
    727
    198
    They are both 12DP gears. Probably for a SB 16" or equivalent lathe.
    Jul 2010
    Virginia, USA
    3,538
    87
    682
    I'd say not from a lathe at all.
    allan
    Apr 2004
    Illinois
    178
    20
    I also got a 7" faceplate that doesn't fit this lathe. It has a 1 3/8 - 8tpi thread. Is there a South Bend lathe that has this thread or should I just bore it out a little and rethread to 1 1/2 - 8?
    Feb 2015
    Florida
    727
    198
    No SB lathe had a 1-⅜" spindle nose thread. The minimum was 1-½" for a 9" and 10K.
    Sep 2010
    moscow,ohio
    6,364
    651
    2116
    Yes, in fact the early 9" workshop had 1 3/8" spindle...i.e.- Model 5, not sure about the tpi though.
    Feb 2015
    Florida
    727
    198
    Quote Originally Posted by iwananew10K View Post
    I wasn't sure about the early-early SB's. All I know is that from WW2 on, no spindles of that size were produced.
    Jul 2008
    South Bend, In
    2,729
    186
    282
    The Model 5 was 1 3/8-10
    Ted
    Apr 2004
    Illinois
    178
    20
    Quote Originally Posted by SBLatheman View Post
    Ted
    It's definitely 1 3/8-8. I don't know what it might fit. Guess it could be bored out and threaded to 1 1/2-8.
    Feb 2008
    newark DE USA
    1,232
    116
    Real question is do you have a faceplate to bolt it to to do the job.Once you have it trued up on a faceplate you can remove it by unscrewing that plate and checking the fit on your spindle. Cast iron threads beautifully.
  11. #11
    Apr 2004
    Illinois
    178
    20
    Quote Originally Posted by k3vyl View Post
    I don't want to turn it into a common 1 1/2 x 8 if someone is looking for a rare, hard to find, 1 3/8 x 8.
  12. Likes SteveM liked this post
  13. #12
    Sep 2010
    moscow,ohio
    6,364
    651
    2116
    could you post pics of both sides of plate and see if there are any casting numbers anywhere?
    I love trying to identify obscure stuff.
  14. #13
    Apr 2004
    Illinois
    178
    20
    No numbers of any kind!
  15. #14
    Sep 2010
    moscow,ohio
    6,364
    651
    2116
    Could it possibly be 1 1/4-8? Common for wood lathes.
