I'm probably purchasing a South Bend 9A this morning. - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 70
  1. #21
    Feb 2004
    peekskill, NY
    26,414
    5932
    Looks well used actually but not much wear. The thread dial indicator fits onto the pin sticking out of the right hand side of the carrige, that threading dial in in your second box of stuff. There is a bed way clamp in one of the first boxes of stuff with a square headed screw with it. That goes into the vertical hole that's empty in the top right side of the carriage.
    Your main task now is to clean all the chips out of the various places in the lathe. You probably will need to slide the headstock off for this, held on with two bolts from underneath. I doubt you will find it advantageous to have this bed redone, it probably will do all you want as-is.
  2. #22
    Feb 2021
    New Jersey
    33
    I dont know what the chucks are just yet. Im short on time right now so I can't get started checking this thing out/ cleaning rebuilding it.
    I might have questions throughout the process. I'm going to tear it down completely and clean it up real nice. Going to rebuild it, paint it, and just start using it. Soon.
  3. #23
    Feb 2015
    Florida
    1,015
    286
    Quote Originally Posted by CVRIV View Post
    If not already mentioned, get the rebuild kit and manual from Ilion Industries from ebay. It will help guide you through your cleaning/rebuild process.
  4. #24
    Apr 2010
    northeastern Pa, USA
    833
    165
    251
    Before you start to use it swap that 40 tooth stud gear with the one (20 tooth) that is parked on the screw beside the 56 tooth. Check you thread chart for arrangement. I doubt you will be threading such a low number treads anytime soon.
  5. #25
    Jan 2021
    Ohio
    87
    36
    12
    Very nice. The ways don't look like they have much wear at all. I'd still do the tear down and rebuild. It'll put it back in like-new condition, and you will learn a LOT in the process, not just about the lathe, but it will give you time to do more research on setup and running the lathe. Great find.
  6. #26
    Mar 2010
    Utah
    753
    87
    61
    I am impressed with all the stuff you got with the lathe, well done enjoy.
  7. #27
    Jan 2005
    Victoria, Texas, USA
    4,522
    2993
    1223
    If the headstock spindle turns freely, I suggest you don't take any of it apart until later in life. Just keep the oil cups full of oil. At least wait until you learn more about the lathe before tearing down the headstock. Ken.
  8. #28
    Jun 2013
    New York
    718
    480
    401
    Nice! You got a good deal it looks like. The ways don't look too bad, they are obviously used but you can tell they were cared for and not abused. Same for the lead screw. When I got my 9A that was all I was looking at -- the ways and the lead screw. And I can hit my numbers no problem. I bet you can hit a thou easy with yours, once you get it all set up and dialed in.
    I've had mine almost a year now, and still getting to know it in some ways. So take your time and find some scrap mild steel or something and see what it likes. Make sure it stays drenched in oil
  9. #29
    Feb 2021
    New Jersey
    33
    The lathe came with the rebuild kit and guide. Im all ready to go. Im going to do a complete tear down, clean, paint and rebuild.
  10. #30
    Feb 2021
    New Jersey
    33
    How do I remove the signage?
    There are only 3 holes inside the bed for someone to possibly tap out the rivets.
  11. #31
    Feb 2021
    New Jersey
    33
  12. #32
    Feb 2015
    Florida
    1,015
    286
    They are called "drive screws". There should be a hole in the back for each one, but there doesn't have to be. People have removed them in the past by taking a Dremel tool and cutting a slot in the head, then just turning them out with a screwdriver.
  13. #33
    Jan 2021
    Massachusetts
    If you cant get at the back of the screws, (likely) use a sharpened very small flat head screwdriver. Tap under the tag around the screw and gently wiggle. Take your time, and the screw should loosen and come out without deforming the tag too much.
  14. #34
    Feb 2021
    New Jersey
    33
    I got them out. I used a small drilbit to tap them out from the inside. One of the little screws didnt have a hole so I carefully pryed it out.
  15. #35
    Apr 2008
    Western PA
    269
    7
    I don't see much of a ridge on the ways. They are in good condition. Lathe is probably good to above average condition to most that are available.
    You have a lot of things with it you will not have to purchase. Learn to use what you have.
    I would have told to you leave the head stock on the lathe bed but you already moved it.
    Get a tooth brush or stiff polymer brush and remove the gunk from the gears as they are in place to see how they turn once cleaned. Don't remove them. You should be able to turn them by hand to see how they mesh. They look very clean to begin with.
    You have the threading dial, a nice option for the lathe. Don't really want to hunt one down but it will be very helpful when threading.
    Clean the gunk out of the lead screw. You will be able to see wear on it a little better. Wear will be on the flanks. Measure tooth thickness by the end or beginning of the lead screw to get measurements. Then take measurements ever 1 to 2 inches to get an idea of lead screw wear. Probably not much. Your half nuts will have more wear.
    Make sure to check the inside of the tail stock and see how scored up it is. Don't want to see a bunch of concentric rings or heavy gouges.
    Overall a great starter lathe with most everything you need.
    Worth is value to the owner and to some extent where you live.
  16. #36
    Feb 2021
    New Jersey
    33
    Why should I not remove the gears? I want to do a complete tear down. I am aware that everything has to be aligned when put back together. I'm probably going to do it anyways because I'm stubborn. Stuff like this is my strength. Thanks for the tips on checking for wear. I will do what you mentioned.
    The ways look great. No grooves or ridges. I did the straight-edge with a light trick to see if the ways dipped towards the cetlnter where the carraiage rides the most and there was nothing. It was so luttle that I cant even consider it be be anything.i dont get it. I thought there would be more. I'll keep checking everything else as I continue cleaning.
    How much paint do you think I need to coat this machine? A quart at minimum? Might just get a gallon of sokething and paint multiple coats. Not going to ask what what because I found old threads here whwre it seems that everyone has their opinions on which to use.
  17. #37
    Feb 2021
    New Jersey
    33
    Also, ive used lathes way back in the day. I'm very familiar with them. I only have to reacquaint myself with this machine. I can't wait to get started cutting.
  18. #38
    Jan 2021
    Ohio
    87
    36
    12
    You'll want to take the gears apart, IMHO, because there's likely other crap up in there that you're going to want to clean out. Plus, there should be at least one gear that will need some new oiling felt.
    As far as paint, I have JUST gone through a quart of paint, and the only thing I have left to paint is the headstock. So of course, I have to buy another quart. LOL.
  19. #39
    Feb 2021
    New Jersey
    33
    Lol. So I bought a gallon of an oil enamel paint and a hardener as well. So I'm good with paint.
    Ive been dismantling everything do to the smallest parts. This machine is amazing. I just got done dismantling the tail stock completely. I found some missing tail stock stuff inbmy boxes of stuff, so the tail stock in cleaned and complete. Ready for a final wiping and paint.
    Its amazing how smooth all these moving parts are despite not having any bearings. How did they or do they get these surfaces so perfectly smooth for such a smooth fit?
    Dismantling everything down to the smallest parts has me finding all the oil locations. How often do I have to oil these locations?
  20. #40
    Apr 2008
    Western PA
    269
    7
    I was saying leave the gears in place and see how it turns after you remove the initial gunk. Just a check so you can gauge what it is like. This was my meaning. I understand you will be ripping everything apart anyway.
    Listen to all, listen to none. Advise is just an opinion and nothing more.
    Your machine is in very good condition. You should not have any problems
