The infamous South Bend 1307 - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 44 of 44
  1. #41
    Mar 2019
    North Carolina
    Quote Originally Posted by Herb in Delco View Post
    Ted--Thank you!
    I assume that your machine has a metric gearing chart inside the end cover, ours has. If you ever get to that point, I reverse engineered the number of teeth on the chart--which are only given as SB part #'s-- and made gears. In reality, there are only two that I think ever got used, inspite of making a lot of foreign car parts, and other metric stuff, on the machine.
    Herb
    Hello Herb,
    I would appreciate your sharing any info you have on those metric QC gears that you made for your 1307. I own the 1307 that Petras mentioned (which came from PA) and I would like to acquire the gearing for metric thread cutting. Here's a picture of that chart you are mentioning.
    Thanks, Alex.
  2. #42
    Oct 2007
    102
    65
    Default Metric change gears for South Bend 1307
    Alex,
    It does not look like my father is going to reply to this, so I'll post a picture. It is just a splined hub and gears with two small screws to hold it against a shoulder. All made in aluminum for expediency and the fact that we did not expect to cut a lot of metric threads. Very simple construction, as you can see. I did not look at the chart inside the cover to see if all the optional gears were made, but did make the following:
    #160077 59T
    #160072 55T
    #160067 51T
    #160062 47T
    As you will note, also stamped the SB part numbers on the gears for convenience when using the chart to figure out the correct thread.
    -Doug
  3. #43
    Aug 2006
    Santa Cruz, CA USA
    63
    15
    Default 1307 again Sidney this time
    Been reading this thread and enjoying it as I have a Sidney 1307 It obviously is the earliest version of the 1307, mine interestingly enough is serial number 13070001 So I have to wonder is it very first and is it the actual one in the operators manual picture. The manual is almost hand made like a prototype
  4. #44
    Oct 2007
    102
    65
    Never seen a picture of the Sidney version.
    -Doug
