shpxnvz
- Feb 13, 2015
- Livingston, TX
From the picture this appears to be a five foot 10R, not a 10L, this lathe is a 1941 cast
base UMD, the chip pan does not appear to be original for a tool room(8199-B) lathe, so the
catalog number would be 199-B. South Bend called this lathe the 10 inch 11/16 collet lathe
because it had the smaller spindle installed, everything else was indentical to a 10L.
These are the starting "S" series lathes that ran for several decades. After the war, in
1946 Bronze shell bearings were added to the headstock.
Thanks for posting this, could you post a picture of the collet closer, this would have to be
a number 2 (collet) closer (say rare), as this lathe used the same collet as the older 11 inch lathe.
Steve
Interesting that it appears to have a cam-style clutch on that era base. Not a combo you see often.
I don't think that is actually a clutch but a handle to lift the motor for changing between high and low speeds on the intermediate jack shaft.
The motor likely has two different sized pulleys and same with the intermediate jack shaft.
Handle has a linkage to motor base which is hinged.
Looks like a Heavy 10L.
Got the lathe unloaded and into the garage and got a little closer look at it and took some more pictures. I'm happy so far, haven't seen any damaged gear teeth and not a whole lot of wear on the ways, still a little flaking visible. Kind of surprised but everything is still pretty well lubricated, the headstock oilers were full, and everything moves freely.
The lathe came from a maintenance shop for a county school system a little north of here. Apparently it's been in storage since before any of the guys I talked to at the shop got there, and they weren't young guys. I don't think they've done lathe work in a real long time the way they were talking so I wonder how long ago it got put away.
I appreciate all the info you guys have posted so far. I have a couple more questions.
I want to get it wired up and running without tearing it apart too much if I can. Going to clean it up and run fresh oil through everything, but there's some rust on the spindle cone pulley and the underdrive pulley that I should probably take care of. Is there good way to do that without pulling the spindle or the drive?
I read through some threads on the 10R here and it seems that it can be converted to a 10L with a few parts but I'm not clear on exactly what needs to be changed out besides the spindle to make that happen?
I got set up to get the lathe off it's pallet and came across a problem. Hoisting with a strap under the bed at the tailstock end the base lifts free of the foot. It looks like the bottom of the ear that stick down in the foot with the cross pins for the adjustment mechanism is broken off.
I did a little searching but haven't found a good parts diagram for the tailstock end bed foot. It looks a lot like this one so I think the broken piece is part of the foot itself rather than the bed (see last photo). I'll try to get a picture of it tomorrow. Does anyone know a part number or name for either the whole foot or just the broken piece? Or even better have a spare sitting around you can part with (unlikely I know)?
Notice
