I use a 13" lathe micrometer stop on my 11", it needs a pad inder the bottom bracket that holds it on. If I find another one, I'll make a permenant modification to one of them. I think the 10" mike stop would be too "short" to reach the pad on the 11" carraige.
I also have attached the 10" threading dial to the carriage of my 11", I don't remember making any modifications at all.
The big boring tool holder for the 10" machine will do nicely on the 11" if you put a 2 5/8" dia by 1/4" thick disc between the top holder and the base. I secured mine together with a pressed-in bronze bushing. You don't have to mod. the base, the tool post slot is the same on the 10" and the 11".
I have a suspicion that the 10" taper attachement can be made to fit the 11". I haven't messed with that because I have too many taper attachements as it is.
My lathe already has a steady rest, but if it didn't I would not hesitate to mod. one from the 10". The 13" steady is way too big.
