enginebuilder
Stainless
- Dec 1, 2005
- Kalispell, Montana
So I'm turning away, all is nice and smooth, everything comes to an instant halt. Loosen belt tension, spindle ok, undo motor drive belts, motor spins nice, the counter shaft is lock up tight as a drum. Take everythign apart ( not a fun job when nothing will spin and let you get to the taper pin and all the set screws). Any way, burs on the shaft locked it to the bracket, dunno why everything was wet with oil. My question is, does anyone know what the to series of grooves machined into the counter shaft are supposed to do? See pic below
Jim
Jim
