I'm going to go out on a limb here and ask another question When I bough the lathe a couple of years ago I changed the motor to a Leeson 2 HP, 1725 Rpm, 230V, Single Phase, 56HZ Frame.
We tried all sorts of wiring arrangements, I had two different electricians drop in and look at it, but weren't able to get it reversing on the drum switch. If I recall correctly, this Leeson has something slightly different in the wiring that complicates the reversing. As it stands there's only 110v on the reverse side, in other words no reverse. I eventually gave up and have been living with just the forward rotation. This is obviously not ideal.
Below is the standard starting point for the wiring, the picture I believe is the current arrangement. I think there were a couple of ways to get 220 forward and 110 reverse, but we never managed to get 220 in reverse.
Since the single-phase conversion is quite common and so are these Leeson motors, I'm wondering if anyone here has installed this particular motor on the standard drum switch and managed to get it turning in both directions without adding a second switch?
