Looking at getting a 5" 3-jaw chuck for my lathe, 2 piece jaws worth it?
Results 1 to 12 of 12
    Aug 2017
    Ohio
    109
    35
    Default Looking at getting a 5" 3-jaw chuck for my lathe, 2 piece jaws worth it?
    The 3 jaw that came with the 9A is in poor shape, so i've exclusively been using the 4 jaw. Getting tired of manually dialing everything, i'm looking into getting a new 3 jaw. As near as I can tell, the recommended size for a 9" lathe is a 5" 3 jaw chuck. Shars has a few in this size, one without 2 piece jaws for ~$80, and one with 2 piece jaws for ~$170.
    It seems like the advantages of the 2 piece jaws are that you don't need to take the jaws out to flip them around, don't have to keep track of a 2nd set of jaws, and could make replaceable soft jaws for it. I don't know if I can buy soft jaws or not for the chuck with plain jaws, and it'd definitely be nice to have this capability. Thoughts?
    Nov 2014
    Florida
    3,430
    1480
    1621
    Yes, get 2 piece jaws.
    Jan 2014
    North Carolina
    442
    15
    117
    I have 3-jaw chucks in both configurations. There are plus and negative aspects for either configuration. With the 2-piece jaw, you don't have to worry about taking jaws out, keeping track of them, and trying to re-sync the jaws with the spiral when you put them back. I find that with the 1 piece jaws--either reversible or with 2 sets--the chuck is less "clunky." The two-piece jaws are big and they will tend to get in the way if you're working up close to the chuck. You may just have to experience both in order to make up your own mind on the topic.
    Feb 2011
    2,046
    1387
    881
    2 piece jaws tend to be easier to source replacements for if/when they get banged up, while one piece tend to have to come from the OEM.
    Jul 2003
    savannah, jaw-ja
    1,720
    1158
    403
    Not going to comment on Shars...but - look at the math.
    2 x $80 is 160. Which is less than 170. Just swap chucks. I have two 3 jaw chucks, one has outside jaws, the other has inside jaws, and hardly ever gets used in my shop.
    OP- you can probably dial your 4 jaw in to the same accuracy you are going to get out of one of those 3 jaws pretty durn quick. They all have run-out. More money, less run-out.
    Jul 2010
    Rochester, NY USA
    2,154
    9
    501
    I have an old Union 5" 3 Jaw with 2 Pc. Jaws.
    I have made several sets of soft jaws for it.
    They are used for applications where I can't fit the part into any of my chucks. Such as a tall dish shape on one side of a part etc.
    Or very thin parts where the step on the standard jaws are way too big.
    Bill
    Jan 2005
    Victoria, Texas, USA
    3,931
    2031
    965
    I have a 6" 3-jaw and 6" 6-jaw chuck on my 9" SBL. I found it to have much better capacity and a tad better holding power than that of a 5" 3-jaw chuck.
    It's funny, I just mounted a 5" 3-jaw chuck on my 14" lathe. I did that to take advantage using the outside jaws to hold thin disks that I couldn't hold using my 8" or 9" 3-jaw chuck.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    Aug 2013
    809
    491
    216
    Two piece jaws so you can use soft jaws when needed.
    Sep 2015
    Florida
    578
    82
    Dialing in a 4-jaw to within 2 or 3 thou (same accuracy as a regular 3-jaw scroll) only takes a minute, I don't see it as a big deal. And, you can dial it in dead-nuts when needed.
  10. Likes Rudd liked this post
  11. #10
    Jun 2012
    Michigan
    9,956
    3358
    3566
    Decent 3 jaw with an adjust true back would be nice.
    2 or 3 thow three jaw would be nice.
    I had a lathe chuck on a grinder that would do 1 to 3 thow .. Most lathes 3 jaws were about .005 or worse. ...some way worse
    So I did most close work in an independent 4jaw or between centers.
  12. #11
    Sep 2010
    Oklahoma City, OK
    4,173
    720
    1761
    Quote Originally Posted by comstockfriend View Post
    I will never again buy a chuck without the ability to use soft jaws, they're too damn handy.
  13. #12
    Apr 2019
    38
    Interesting thread as I am thinking of getting either a 5" or 6" Shars 3 jaw, 2 piece chuck for my 9A. Sorry, I can't afford anything more. But since I have a very nice tight Skinner 4006 6" 4 jaw, I'm thinking to buy the less expensive 5" to replace the 5" Cushman 3 jaw. Aside from being a little less expensive than the 6", I have a cast iron bar bell weight that is just wide enough to turn a back plate that costs me $6.
    My question is even though I have a 6" 4 jaw, will I miss the rather significant size capacity of the 6" if I get the 5" 3 jaw 2 piece chuck?
  14. Likes Domodude17 liked this post
