Looking for hand wheel crank handle
treva
Feb 8, 2015
I have a 13" SB lathe. I need a crank handle for the tail stock hand wheel. Did South Bend use different size crank handles for each size lathe or was it the same size on all their lathes? I want to keep everything looking original. Thank you.
you have a lathe , make one
animal
I had to replace the handle on my Heavy 10 due to gross stupidity on my part. I found a rough cast handle of the correct dimensions at either McMaster or MSC and machined it to fit. It's very difficult to tell it from the original.
