Looking for info/advice on my SB 9" lathe - Page 2
Results 21 to 40 of 45
  1. #21
    Sep 2004
    Fort Worth, Texas
    2,166
    283
    189
    Quote Originally Posted by SpongeRich View Post
    Another option for dealing with the rust is to use some Evaporust. (Available at most auto parts stores). You can soak a rag and cover it with some plastic wrap. Let it sit overnight and it should clean that rust up without any abrasives. I've soaked parts in it for over a week and it won't touch any good metal, but removes the rust quite well.
    I just pulled a 9" Logan bed out of an overnight Evaporust soak. It was MUCH worse than yours. Looks nearly new today
  2. #22
    Dec 2012
    Oshkosh WI
    137
    27
    6
    mine really wasnt to bad, I just used 0000 steel wool on it. I have decided after pulling the lathe apart a bit to change the wicks, just to go ahead and paint her up too. I figured I might as well since I am taking it apart anyways. The quick change gear box brass bushings were super tight. The gallon of carb cleaner works awesome
  3. #23
    Dec 2012
    Oshkosh WI
    137
    27
    6
    Progress so far ;-)
  4. #24
    Oct 2009
    Colorado
    1,092
    8
    94
    Good - I see you got the rebuild book.
    Did you slot the original drive screws that fasten the gear box nameplate, or are those new? If they're new, how did you remove the original ones?
  5. #25
    Dec 2012
    Oshkosh WI
    137
    27
    6
    Yes, I got the rebuild manual and Oil kit. The rebuild has been very straight forward so far. I cut a slot in the drive screws, taped the head with a hammer lightly to free them up and turned them out. I did re-use the originals.
  6. #26
    Dec 2012
    Oshkosh WI
    137
    27
    6
    Anyone see a problem with the wear on this Traverse gear?
  7. #27
    Oct 2009
    Colorado
    1,092
    8
    94
    I think that'll work just fine.
  8. #28
    Jul 2011
    Lac Du Bonnet,Manitoba
    636
    60
    72
    looking good so far.
    i also have a 9a,no milling attatchment,but a taper attatchment and a toolpost grinder.
    nice looking piece.enjoy.
    i dont regret buying mine.
  9. #29
    Dec 2012
    Oshkosh WI
    137
    27
    6
    Ok, good to know This lathe came with some kind of grinder, It looks like it runs off the lathe belt system. I'm not sure how it hooks up though. I'll be looking into that once the lathe itself is in good shape.
  10. #30
    Dec 2012
    Oshkosh WI
    137
    27
    6
    A couple pictures of the progress. I've been working on the lathe quite a bit the last few days.
    First pic is playing: how many lathe parts can you find in the picture
    guess a pic of my monster got on here as well.
  11. #31
    Dec 2012
    Oshkosh WI
    137
    27
    6
    Default almost ready to start assembly
    I am having a tuff time getting the lathe bed clean. Every other part I have bead blasted or let soak in carb cleaner. But the bed is too big for either method. Any thoughts on how to get it degreassed really well? Pics of progress:lathe321-001.jpglathe321-002.jpglathe321-003.jpglathe321-004.jpglathe321-006.jpg
  12. #32
    May 2012
    Tennessee
    32
    50
    14
    Looks nice. Wish I had the patience to paint mine
  13. #33
    Oct 2009
    Colorado
    1,092
    8
    94
    Kerosene or WD-40. Or simple green, undiluted, then hit it with a garden hose. Or take it to your local carwash and hit it with the wand.
  14. #34
    Dec 2012
    Oshkosh WI
    137
    27
    6
    It does take a ton more time to paint, but it does look sharp all painted up. I am getting sick of painting....but im almost done.
    I'll pick up some simple green and use my pressure washer.
    Quote Originally Posted by SpringGunner View Post
  15. #35
    Feb 2013
    NH
    266
    33
    21
    I bought a $40 parts washer from harbor freight and filled it with SuperClean (purple power...same stuff) and i also threw in two small submersible fish tank heaters. Works extremely well for cleaning anything that fits in it. When I get to the bed, I will probably use a big rubbermaid tote, but the SuperClean is still the best degreaser I've found.
  16. #36
    Dec 2012
    Oshkosh WI
    137
    27
    6
    green stuff and hot water through the pressure washer was awesome
  17. #37
    Oct 2009
    Colorado
    1,092
    8
    94
    Well, that was quick.
    With my 1st SB, I tore it apart, cleaned, stripped and painstakingly painted it. With my 2nd SB, I decided I'd had enough of stripping and painting, took it apart, cleaned it, put it back together and used it.
  18. Likes barrakudaman liked this post
  19. #38
    Dec 2012
    Oshkosh WI
    137
    27
    6
    What do you guys recomend for a drive belt? Link style? Where do you get it?
  20. #39
    Feb 2013
    NH
    266
    33
    21
    Im planning to go with automotive serpentine...from napa...but I dont know a part number yet...I think you have to measure your belt and convert it to mm and then the parts guy should be able to find you one...or so ive read.
  21. #40
    Dec 2012
    Oshkosh WI
    137
    27
    6
    I have v-belt drive
    Quote Originally Posted by freeclimbmtb View Post
