Lube tubes on a SB 7 inch shaper and need a ram gib..
Results 1 to 6 of 6
    Jan 2002
    Alaska
    54
    881
    23
    Default Lube tubes on a SB 7 inch shaper and need a ram gib..
    I doing a total rebuild on my 7 inch shaper. I removed the oil pump after unsodering the oil tubes,
    It had 3 tubes 2 for the ram and one for the bull gear. On the parts sheet it shows 4 tubes the block on the oil pump had been repaired ( blotches repair at that) the tube for the rocker had been sodered up for some reason. Is there a picture of how the correct lines are routed? Also I need a ram gib. Does anyone have a pictures of one so I can reproduce one or a spare to sell?
    Will post pictures soon
    Steve 3512 b
    Jan 2002
    Alaska
    54
    881
    23
    Default ft of shaper
    working with my pictures heres a start
    Feb 2014
    NorthWest Mississippi
    13
    I redid my sb 7 shaper several years ago. There are several old threads on the forum about this. My pictures really didn't show much.
    If my memory is correct...... There are 4 outlets on the oil pump maniford. 2 are adjustable and 2 are not. The two adjustable go to the dovetail slides (Note: research oil line to the gibb). One of the Non-adjustable lines goes to the bull gear and main drive shaft. The other is soldered to bottom of the bracket of the gibb oil line.
    I replaced all mine with new 1/8th inch Tach oil lines from auto parts store.
  4. Likes 3512B liked this post
    Jan 2002
    Alaska
    54
    881
    23
    Default oil lines befor i removed pump
    this is whatshaper-oil-lines-resized3.jpg I have before I removed the pump
    Jan 2002
    Alaska
    54
    881
    23
    Default more oiler pictures
    I Added the 4 oil line to the oiler block I have it long and will adjust
    on final assembly
    Jan 2002
    Alaska
    54
    881
    23
    the piece of tube that goes threw the ram gibe was sheared off :{. not having a small angle drill, it was time consuming getting the piece out, I worked the hole in the tube big enough to get a small tap in it. It caught enough for me to pull it out.
    Attached Thumbnails Attached Thumbnails ram-gib-oiler-bb.jpg   ram-gib-oiler-cc.jpg
