Hi Guys,
I don't understand the procedure for lubing the back gear shaft and cone pulley. I also don't understand the lubricant type. It says "oil", but there is a recommendation to use grease. Through that wee teeny hole? How much? Hmmm.
I found a video by Mick Finch of Bluechipmachineshop channel on youtube, but I'm still confused. Mick refers to Roy Dean grease that is out of production. Hmmm.
Which lube do you you use? How do you install it? Do you ever clean out the old lube? If so, how?
I tried using the search feature, but it just said, "sorry, no matches found". Again, Hmmm.
Thanks in advance
R, Steve
Thanks in advance
R, Steve
