Lubrication
Likes Likes:  0
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 62
Thread: Lubrication
    May 2008
    greenwood,sc,usa
    21
    Default Lubrication
    Hello, I have been trying to find teflon grease and non detergent oil in 5, 10 or 20 weight with no luck. Can somebody tell me where I can order this.
    Thanks a lot for any info you can give me........Jerry
    Mar 2009
    Eureka, CA
    3,773
    751
    1306
    rapidtap,
    There is a synthetic grease with Teflon...it's called Super Lube and probably available many places. Google it! If you are hunting for a non-detergent 'motor oil' in any other viscosity than 30 weight you are probably not going to find it.
    As this forum deals with machinery, I'm guessing you are looking for an industrial oil rather than a motor oil. The application would indicate what type of oil to use. Do you have a manual that says to use a ND motor oil?
    Stuart
    Aug 2008
    Queensbury, NY
    251
    14
    I got SuperLube at Ace Hardwre
    Ron
    May 2008
    greenwood,sc,usa
    21
    Default lube chart
    I'm thinking I read in one of the posts where it said to use nd oil or use 20 if I couldn' find the nd oil correct me if I'm wrong.
    May 2008
    greenwood,sc,usa
    21
    Default oil
    My mistake, it said to use nd engine oil only if no other oil is available. Sorry my mistake. Now what I want to know is 20w motor oil is whaat I need for my lathe
    May 2008
    greenwood,sc,usa
    21
    Default super lube
    Thanks Ron, I saw super lube at car quest but I wasn't sure about it
    Jun 2008
    Indiana, USA
    69
    9
    I had looked for "lube" a couple places, and got tired of the dead end. I pulled up McMaster Carr , and the very next day, the velocite 10, vactra 2, and the 20w, along with some synthetic grease with teflon, was sitting at my doorstep.
    May 2008
    greenwood,sc,usa
    21
    Thanks Nutzfor tool. I have been off base but I.m straight now, Thanks to every one for all the help.........Jerry/rapidtap
    May 2005
    pacific southwest
    343
    wait for enco to offer free shipping, that's what I did.
    Jun 2006
    Dayton, OH
    691
    23
    Here's what I'm using, in case it helps.
    Ryan
  11. #11
    Nov 2004
    Birmingham, AL
    13,228
    6615
    2561
    Tractor Supply carries non-detergent, straight mineral oil in 10, 20 and 30wt. They were out of 20wt, so I bought a jug of 10 and 30 and mixed equally to get 20. Still have plenty of 10 and 30 left over for those applications.
  12. #12
    Jan 2003
    Port Allen, La. 70767 USA
    300
    Talking Oil for Southbend
    Hi all: In my 1957 sixteen inch I use Exxon nuto 68 in everything but the spindle bearings and the apron sump where the feed clutch is located.
    In the spindle bearings and feed clutch I use Lubriplate spindle oil #1 I think.. It has been so long since I bought any.. Still have alot in a metal gallon can..
    I've heard about using teflon grease in the backgear but I still use oil.. Just put a little in it when you use backgear.. Mike
  13. #13
    Mar 2009
    Eureka, CA
    3,773
    751
    1306
    rapidtap,
    I'll have to eat crow on this one. After 'Mike C' posted I was skeptical so I snooped around. There are non detergent motor oil still made in all the viscosities you were looking for...you learn something everyday. My first choice would still be a industrial oil in the weight you are after. I have linked the non detergent site just for grins.
    http://www.burkeoil.com/pdf/nonde1.pdf
    Stuart
  14. #14
    Jan 2003
    300
    Quote Originally Posted by atomarc View Post
    rapidtap,
    Stuart
    I tend to favor hydraulic oils in the iso 68 range for everything but the spindle bearings and the feed clutch in my 1957 Southbend sixteen inch.. The hydraulic oils have good anti wear anti rust additives that enhance their use in machinetools..These oils are availible at Walmart even usually iso 46 in five gallon pail...Mike
  15. #15
    Nov 2004
    Birmingham, AL
    13,228
    6615
    2561
    I was warned by our lube rep at the shop that some of the modern hydraulic oils are rough on bronze and brass (red metals). He ordered some different stuff for the big Pacemaker for this reason. That's why I am running the straight non-detergent mineral oil in my machines... all of them.
  16. #16
    Jun 2008
    Cincinnati,Ohio
    513
    Quote Originally Posted by Grey Rider View Post
    Ryan
    Nice photo oil chart Ryan.
    Don
  17. #17
    Jan 2003
    300
    Talking Oils For Machinetools
    Quote Originally Posted by Mike C. View Post
    Some of the oils that have ep additives can be hard on brass or bronze.. I think they are sulphurized.. Oils such as hypoid automotive oils should be avoided although I use those for cutting oil in my old Kearney and Trecker mills... Mike
  18. #18
    Mar 2009
    Alabama, U.S.A
    610
    14
    Default aircraft turbine oil?
    Anybody know if this would be an acceptable spindle oil? An older fellow down the road used to be a mechanic at a small airfield, I saw it sitting in the corner of his shed and he gave me a can. I forget the weight but I know it's pretty thin. Maybe 10-10 or 10-20, i'll go look and post the specifics. Thanks for any help, m71.
  19. #19
    Jun 2006
    Dayton, OH
    691
    23
    Quote Originally Posted by phantom71 View Post
    Isn't turbine oil usually single-viscosity? As long as the viscosity is in the correct range, I suspect it will work fine.
    Ryan
  20. #20
    Mar 2009
    Alabama, U.S.A
    610
    14
    Ryan
    Sorry I have'nt had achance to run check what the specs are. Be back in 10 mins, the missus' just got home and needs a moment of my time. . m71.
