Now that I've got my Sheldon up and working I'm determined to try to fix the tailstock tilt on my 9A.
I shimmed the base when I first got the lathe- but did it evenly front/back to bring center to the correct height with the spindle retracted and locked (makes little difference whether locked or not, there's good fitment).
With the spindle extended, there's .004 of "drop" towards the headstock over the 2" length. Add the length of a chuck, and a long drill bit, and it can easily exceed 15 thou. It's impossible for me to do second ops like opening up an existing drilled hole without wallowing it out.
If I'm correcting .004 over a length of 2", how can I calculate how much less the rear of the base needs to be shimmed as compared to the front, to level it out?
