Messed Up My SB Lathe
Results 1 to 20 of 20
    Mar 2020
    11
    Default Messed Up My SB Lathe
    Hey All,
    New to your forum. I needs some help and advice. This morning I made the fatal error of moving gears while my lathe was still just moving... BANG! a few choice words after that, I knew I screwed up.
    Pulled the cover off the left side and found I had sheared a few teeth off a gear. Not sure what this gear is called so I posted a couple of pictures.
    Is it possible to find this piece? It's Sunday so I will call SB tomorrow, I think it's a Government unit, S/N 105631. No letters, they will most likely tell me nothing.
    Dimension are; Center hole 1.1225". Outside Dia. 4.190. & .5" thick. The smaller gear was pressed in and not damaged.
    I sure would appreciate any help at all, I really enjoy this lathe. Owning it for well over 20 years I just can't believe I did what I did.
    Thanks guys,
    Chris Campbell
    Feb 2015
    Florida
    658
    164
    What model lathe? Gears were different for different lathes.
    Don't call South Bend, call Boston Gear - that gear was replaced years ago.
    Feb 2015
    Florida
    658
    164
    My best guess would be this gear on Amazon.
    You'll have to bore it to size and press the small gear in. They both should be pinned together and not rely on the press to hold them together.
  4. Likes Greg White, coyotechet liked this post
    Mar 2020
    11
    I wish I knew the model, It has a 13" swing that is what makes me think it's government, that and the green color.
    Thanks so much for your help.
    Mar 2020
    11
    That looks really promising!! Pin for sure. Seriously you made my day.
    Thanks, Chris
    Feb 2015
    Florida
    658
    164
    You need to know the Diametral Pitch (DP) of your gear. DP is number of teeth + 2 divided by the outside diameter (OD).
    DP= (N+2)/OD
    If you recheck the OD of the gear and find it closer to 4.125", then your DP is 16, like that in the link.
  8. Likes Chris Campbell liked this post
  9. #7
    Mar 2020
    11
    Quote Originally Posted by SLK001 View Post
    DP= (N+2)/OD
    Just ran over to the shop it's a 4.25" outside diameter.
  10. #8
    Mar 2020
    11
    Dang it yes it is 1.125!! man this has been a crazy day.
    Thanks so much for your advice & Help.
    Chris
  11. #9
    Feb 2015
    Florida
    658
    164
    Quote Originally Posted by Chris Campbell View Post
    Chris
    I think you better check again. Perhaps you measured the wrong gear?
  12. #10
    Mar 2020
    11
    LOL Well yesterday was a bad day. yes it is 4.125" The last Gear they had I ordered.
    Chris
  13. #11
    Jul 2004
    Houston, TX USA
    30,716
    My old BG catalog confirms you did good
  14. #12
    Sep 2004
    Alabama
    604
    114
    If the lathe is old, it will have gears with a 14.5deg pressure angle. Newer gears have 20deg pressure angles.
  15. #13
    Mar 2020
    11
    It's old, not sure how old but it works great. literally built all my suspension bushings for a formula ford now building parts for a land speed roadster. Really makes you feel good to build stuff on an old loose machine.
    Gear should be here tomorrow, I have a friend with a 10" SB. He has a large chuck that we can bore the center out.
    Chris
  16. Likes Rex TX liked this post
  17. #14
    Feb 2015
    Florida
    658
    164
    Bore it to a light press fit. Too much pressure will crack a cast iron gear. Then, drill a hole the size of your pin right on the line where the two gears meet and pin the two together.
  18. #15
    Mar 2020
    11
    Works perfect. I hung the old busted gear right above the lathe... Just a reminder :-)
    Thank you so much for all your advice and help,
    Chris
  19. #16
    Feb 2015
    Florida
    658
    164
    Chris
    Good job getting things back in order. I don't see a pin. Is it a roll pin and I am only seeing edges?
  20. #17
    Jul 2010
    Virginia, USA
    3,516
    87
    670
    Sure looks like a flathead set screw to me?
  21. #18
    Jan 2014
    Utah
    626
    1596
    268
    Quote Originally Posted by kitno455 View Post
    Good eyes! I see it now under uber magnification.
  22. #19
    Jun 2012
    Michigan
    11,286
    3863
    3985
    Bad things happen...Good having a machine that parts can be found...
  23. #20
    Dec 2007
    Central Ohio USA
    3,939
    91
    1766
    Wall of shame reminder right at the tool is a good approach.
    I should take some bent valves and make a totem to hang from my son's BMW 5 series...
  24. Likes MetalCarnage liked this post
