Good Day all,
I rebuilt my 1951 Model 9A several years ago and used it very little. I followed the information published in the South Bend (Ilion) guide entitled 'A GUIDE TO RENOVATING THE SOUTH BEND LATHE 9" MODEL A, B & C & MODEL 10k HORIZONTAL DRIVE, as well as advice from this forum.
Now that I have a need for the lathe and started using it, problems have arisen. Before I start disassembling things and using up my very limited and precious free time, I thought to seek some advice form those who know a lot more than I about these machines. My issues are as follows:
1. The head stock heats up when running, even with the belt tension adjustment set quite loose.
2. Even when the head stock is very hot, I can turn the lathe off, un-tension the belt and the chuck/spindle turns with no drag.
2. The new serpentine belt slips and the chuck slows down significantly even under light loads. I can easily slip the belt and stop the chuck by hand after it runs for awhile.
I changed the spindle bearings and wicks during the rebuild and set the cap bolts according to spec. I've loosened the cap bolts since then with no decrease in the head stock temperature. I am using the specified spindle oil.
I first thought that the spindle was seizing in the bearings, but as stated above, even when the head stock heats up significantly, I'll turn the lathe off and can then turn the chuck by hand with no significant drag.
Any Ideas?
Any Ideas?
