My new to me lathe, overpowered? - Page 2
Results 21 to 40 of 42
  1. #21
    Apr 2020
    79
    9
    For now I got that 1/3 hp 1725 rpm motor switched over. What a difference! That other motor was just big and loud. I'm curious what my speeds are. Ill dig up a timing light. I can time a chuck like I would time a car engine pulley right? Lol
  2. #22
    Jun 2012
    Michigan
    14,248
    4855
    5137
    If your low speed is 60 to 80 on the plate you can put a piece of tape in one jaw and time it fairly closes just counting, then figure the rest of your speed are off/on by the same percentage.
    Oh man, you left the chuck key in the chuck, just wait till the guys notice that.
    *Nice looking lathe.
    You might have the local bender(furnace guy)bent you a chip tray.
  3. #23
    Virginia
    21,092
    7561
    12321
    Quote Originally Posted by Matt_50 View Post
    Surely.
    Just remember to connect the timing light trigger lead to the FIRST spark plug on the Napier Sabre engine, not the 48th.
    Somewhere .. still in the blister pak - I have an El Cheapo that can read either of a magnetic button or an optical reflectance tape.
    I actually USE a vintage James Biddle mechanical, though. And "often".
    DC motors don't have "fixed" RPM. Brush timing matters, too.
    Easier to time your AC one - which DOES have known RPM - with a Stanley Powerlock II tape-measure o/e.
    Pulley size thing.
  4. #24
    Nov 2007
    648
    262
    185
    Before too long, I expect the inevitable question of how to wire a drum switch to the motor.
    BTW, nice-looking machine and bench, from a distance at least.
    Just saying.
  5. Likes 1yesca liked this post
  6. #25
    Jun 2012
    Michigan
    14,248
    4855
    5137
    Depending on how it feels for your height you might put perhaps 2 to 4" risers under the feet to make cleaning the bench easier.
    If you are new to lathe work a first practice project might be a T Tap wrench that has a hole from the but end going 2" in that slide on a straight rod held in your tail chuck.. A handy device. and you can also use it on the drill press.
    Shank can be 1/2 dia and the but-hole 1/4(drill)... (or any combination you choose.)
  7. #26
    Feb 2008
    newark DE USA
    1,280
    126
    Tex is right the 3450 is the problem.You could put a 5 HP 1800/4 pole motor on that machine and not hurt it, but the 3600/2pole motor will run the machine faster than the manufacturer recommends. Its as simple as that.
  8. #27
    Nov 2007
    marysville ohio
    10,773
    3017
    7441
    O dear, does all this micro motor loving mean I have 2 much HP on my 13" Holbrook? I have 5HP with a VFD. You guys crack me up, you could put 25HP on that little toy and not hurt it. It has a tiny flat belt drive. If you have a case of temporary stupidity or just run short on talent and crash it the belt will slip and nothing will happen.
  9. #28
    Virginia
    21,092
    7561
    12321
    Quote Originally Posted by mcload View Post
    [SIZE=3]Before too long, I expect the inevitable question of how to wire a drum switch to the motor.
    Phht.. no class.
    How about a bass fiddle? Or an Alto Sax?
  10. #29
    Jun 2013
    New York
    1,076
    730
    607
    Quote Originally Posted by moonlight machine View Post
    Why would the belt slip? Mine stops everything dead, and you can see the tool post flex by probably 200 thou. That is with the stock 1/2 HP motor and a serpentine automotive belt.
  11. #30
    Nov 2007
    marysville ohio
    10,773
    3017
    7441
    You must have the special order rubber tool post.
  12. #31
    Apr 2018
    9,271
    4491
    Rocker tool post, high speed steel. One a these days pavt is gonna try out them new-fangled brazed carbide thingies
  13. #32
    Jun 2013
    New York
    1,076
    730
    607
    Quote Originally Posted by EmanuelGoldstein View Post
    Nope, sorry. AXA post with a (usually) CCGT holder in it. The entire machine flexes that much if you stall it dead in back gears because that's around 80-90 ft-lbs. Said torque being due to the speed reduction and gear reduction.....
  14. #33
    Jun 2013
    New York
    1,076
    730
    607
    Actually nope, its a regular AXA post with carbide. Stalling the entire machine while in back gears is good for 80-90 ft-lbs all of a sudden, things move.
  15. #34
    Nov 2007
    648
    262
    185
    Phht.. no class.
    Yes, I now regret writing that ill-conceived post. I meant that as being tongue-in-cheek at the time. My apologies to Matt_50 as I meant no disrespect.
    I will strive to always write perfect, politically correct posts like you and everyone else on this forum. Thanks for pointing out my mistake, thermite.
    PMc
  16. Likes pavt liked this post
  17. #35
    Aug 2012
    California, Central Coast
    5,404
    2413
    2249
    PMc
    So you wont be posting in that covid thread?
  18. #36
    Nov 2007
    648
    262
    185
    Quote Originally Posted by Rob F. View Post
    What does that mean? I have no idea what you are talking about.
    What covid thread?
  19. #37
    Virginia
    21,092
    7561
    12321
    PMc
    What mistake? I just thot there was too many folks wiring switches to drums and ignoring all the other musical instruments.
  20. #38
    Virginia
    21,092
    7561
    12321
    What covid thread?
    PM keeps a sort of independent in-house insane asylum for overflow when we get crazier than usual.
    ISTR it is currently contracted-out to a 200 year-old retread Limey Bolshevik who has downsized from Craven Brothers lathe-herder to a fully-licensed wheelbarrow operator or some such in his dotage?
    You don't really want to go there any more often than to poke it with a stick or toss in a smoke-grenade every now and again ... then scarper-off.
  21. #39
    Feb 2016
    2,259
    1592
    980
    What covid thread?
    The Southern sections of PM are generally more civilized, South Bend, Antique etc.
    If you ever dipped a toe into the General section, it might be a wake up call. This could be potentialy surpassed by some threads in Manufacturing. The Covid thread is 237 pages of pleasantries
    100,000 UK Covid 19 Deaths
  22. #40
    Virginia
    21,092
    7561
    12321
    Quote Originally Posted by texasgunsmith View Post
    If you ever dipped a toe into the General section, it might be a wake up call. This could be potentialy surpassed by some threads in Manufacturing. The Covid thread is 237 pages of ^^^ piss-ant sleaze ^^^
    There. Fixed that for you.
  23. Likes texasgunsmith liked this post
