My South Bend 9A restoration is nearly complete. Its runs. Have video.
Page 1 of 2 12 LastLast
Results 1 to 20 of 34
    Feb 2021
    New Jersey
    79
    11
    Default My South Bend 9A restoration is nearly complete. Its runs. Have video.
    https://youtu.be/bRkcMH0GBHc
    Let me know what you think. The biggest disappointment im dealing with is that the side cover doesnt fit the machine with the motor and position of the motor assembly. The motor is in the way and the cover wont fot by any stretch of the imagination. Im going to have to figure something out with that. I might try and create a custom cover or mount the cover the the table.
    Speaking of the motor assembly position, i have that thing so finely positioned that the belt tracks to the center of each pulley in forward and backward. Im extremely impressed with that.
    Have having installed the new vbelt, the serpentine belt cones to close the motor juntion box. Ill have to design and 3D print a newer lower profile box.
    Vefy soon we're going to play what is this and what does it do or for. Some of this stuff i have nonidea what its used for.
    Anyways, let me know what you think. I still have some things to do. I want to install a stainless cap on the bench shelf. I need to make an oil/ chip pan for under the bed. I have several chucks to clean/ restore.
    Feb 2011
    BFE Nevada/San Marcos Tx
    2,896
    2959
    1835
    What rpm motor? Seems a bit fast, but maybe just the audio? Paint motor to match lathe, that neon blue is harsh on the eyes.
    May 2014
    Ohio
    45
    22
    Looks really shiny, love the paint. That was running on the fastest speed so lots of gear noise. I didn’t see oil dripping or slinging so it needs more. The cover will help with the slinging oil, so getting that in place is required. If you move the base mount of the countershaft assembly back to the edge of the table will that give you clearance to mount the cover?
    I thought I remember reading somewhere that South Bend didn’t recommend running in back gear on the highest speed setting but I can’t find a reference.
    Oil it up, make some chips and get it dirty, enjoy it.
    Ben
    Jan 2014
    Utah
    731
    1908
    361
    Quote Originally Posted by BDRetz View Post
    ... I thought I remember reading somewhere that South Bend didn’t recommend running in back gear on the highest speed setting but I can’t find a reference. ...
    Page 23 of the 1966 56th edition of South Bend's How To Run A Lathe booklet says at the bottom, "It is not recommended that back-gears be engaged when drive is operated at high speed."
  5. Likes 4GSR liked this post
    Feb 2021
    New Jersey
    79
    11
    Its a 1750rpm motor.
    Havent read the book yet.
    There was plenty of oil spray and spillage. I wiped it all up. Lord have mercy this is going to get messy. Got to stay on top of that. Have to do something about oil spraying on the motor. I dont like the blue motor but im not painting it. Inneed to move on amd get some work done.
    As for the cover.... Id have to get a longer serpentine belt and move the lathe further away from the motor mount. Do i really want to do that....
    Apr 2010
    northeastern Pa, USA
    931
    178
    264
    Change that 40 tooth stud gear out with the 20 tooth so you will have slower gearbox settings available (the more common feeds). Nice job!!
  8. Likes woodchuckNJ, pavt liked this post
  9. #7
    Apr 2010
    931
    178
    264
    Look in the South Bend forum here a few pages back, I have headstock guards for free that you can mount you electrical switch on. If you want them PM me. That repair is easily massaged so that nobody would even know it was there after paint.
  10. #8
    Feb 2021
    New Jersey
    79
    11
    Awesome! Ill PM you.
    I already disassembled the lathe again. Buying a longer serp belt now. Worst thing about this is that i have two extra holes in my work bench. Less than perfect
  11. #9
    Jan 2014
    Utah
    731
    1908
    361
    Quote Originally Posted by CVRIV View Post
    No worries. They will be covered by your planned stainless steel top. And we won't tell.
  12. #10
    Feb 2011
    2,896
    2959
    1835
    Still wanting to know what paint, asked here and waiting for an answer Have a few random questions about my 9A restoration.
  13. #11
    Feb 2021
    New Jersey
    79
    11
    Quote Originally Posted by dalmatiangirl61 View Post
    Its Rustoelum oil based protective enamel. Sorry for late reply. Ive got a lot on my mind.
  14. #12
    Feb 2021
    New Jersey
    79
    11
    Made changes. I got the gear cover on on the bed. I bought a slightly larger serpentine belt and moved the lathe forward from the motor mount by 3 inches. That gave plenty of room for the cover to be attached.
    I have a slight problem now. I have to make a new tentioning mechism because the one was junky. I already tried bending a 3/8" rod to 90deg with heat and that didnt go well at all. I have a small dual mixture jewelers torch. Going to buy a can of propane and oxygen for it. Going to see if i can make that bend with the rod red hot. If i fail,... Anyone know anyone that could do it for me? Im going to scour the net to see if i can buy something i can use.
  15. #13
    Feb 2011
    2,896
    2959
    1835
    Your response in other thread said Krylon, did a google search and found a Krylon gloss black in 1 gallon cans (you mentioned thinning it so I assumed it was not rattle can), now you are saying rustoleum? It looks good, I have a few things to paint in black, could you please provide a link to the paint you used? Home Depot is 2 hour drive away so I can't just go look.
    Did you spray or brush?
  16. #14
    Feb 2021
    New Jersey
    79
    11
    My post keeps getting deleted. Its Rustoleum oil based paint. I thinned it and brushed it on.
    https://www.homedepot.com/p/Rust-Ole...B&gclsrc=aw.ds
  17. Likes dalmatiangirl61 liked this post
  18. #15
    Aug 2004
    ventura,ca.usa
    542
    149
    Beautiful job CVR, that black really looks good on your machine. One suggestion though, possibly chips will find their way into the fan housing of the motor, something to deflect them might be in order. Jim
  19. #16
    Feb 2021
    New Jersey
    79
    11
    Quote Originally Posted by jmm03 View Post
    Agreed. And oil. Im working on it... Hopefully soon this thing will be complete.
  20. #17
    Feb 2015
    Florida
    1,067
    316
    What is that red stuff around the rear head stock bearing?
  21. #18
    Feb 2011
    2,896
    2959
    1835
    Thanks, grabbed the last quart at ACE today, should be enough for one of my projects, hope it retains the gloss outdoors longer than what I've been using.
  22. #19
    Jun 2013
    New York
    903
    612
    481
    Looking good. I can bend it for you if its too much of a problem. Have full-size oxy-acetylene here with fresh tanks. The only time my shop was ever that clean and nice was when I first installed mine. Been a mess ever since because I am using my shop, and I've learned how to accept that.
  23. #20
    Feb 2021
    New Jersey
    79
    11
    Quote Originally Posted by pavt View Post
    Thanks so much. Ill let you know. I bought a 3/8" mild steel rod, a new small tank of propane and oxygen for little jewelers torch. I also bought left and right handed die to thread the pieces.
    Im somewhat sure ill be able to bend that rod once i get it rod hot. If i fail, ill let you know. Thanks.
    So this "shop" of mine really isnt a shop. I wish i had a real shop. Ill just say that its where i do my work😁. I usually keep it super clean in there because i most do electronics and 3D printing stuff.
