Yan Wo
Stainless
- Jan 22, 2014
- Highland, Utah, USA
In Steve Brooks' excellent book, A Guide to Renovating the South Bend Lathe 9" Model A, B & C, he states that after properly adjusting the take-up collar the, "spindle should turn easily."
The "Headstock Bearing Adjustment" PDF on Wells' excellent web site at <http://www.wswells.com/data/howto/Spindle_Bearing_Adj_9_10k.pdf> says to "... be sure spindle turns freely."
I know I'm being Mr. Pedantic, but I'd like a less subjective metric than easily or freely.
With the reversing gears disengaged, and the belt take-up collar and bearing cap screws loose, I can't get the spindle to turn more than one and a half revolutions when I spin the bull gear as forcefully as I can. Is this normal, or should the spindle rotate for several turns before stopping?
And for some reason, the spindle turns more smoothly in the reverse direction.
The spindle sounds like its bearings are dry, even though the oil cups are full. I slid out the shims and can see a film of oil on the spindle, so I think it's properly lubricated.
What do you think?
Thanks!
Jan (Yan)
What do you think?
Thanks!
Jan (Yan)
