Need Bull Gear for SB 10L (Large Spindle)
Likes Likes:  0
Results 1 to 10 of 10
    Oct 2019
    Default Need Bull Gear for SB 10L (Large Spindle)
    Hey there,
    I have a 1983 10L, large spindle lathe with three missing teeth on the bull gear. If you have an extra, I'd like to speak with you about buying it.
    Sincerely,
    G. Fowler
    Mar 2011
    Geneva Illinois USA
    6,341
    2747
    2468
    those are rarer than hens teeth. Too many use the back gear to lock the spindle will trying to remove the chuck or other.
    Tom
    Oct 2015
    Virginia
    569
    19
    132
    I think OP is squared away now.
    Sep 2015
    Florida
    669
    5
    98
    There's some guys 3D printing various SB gears and selling on Fleabay.
    Might be enough demand to approach them about it.
    Oct 2019
    Thanks for the replies, guys. I found one on Ebay. It was pricey. But since these particular gears are probably the ones most commonly needed, for the reason pointed out above, I felt lucky to find it.
    Feb 2015
    Florida
    533
    117
    Quote Originally Posted by tobnpr View Post
    I seriously doubt that a plastic gear could hold up better than a cast iron one.
    May 2010
    NY, USA
    66
    11
    I saw a post a while ago where someone repaired theirs. They made a tooth on a shaper I believe, cut a matching groove in the gear and brazed it.
    Ken
    Apr 2011
    Vancouver, Canada
    122
    5
    Repaired mine with 7 broken teeth 10 years ago, still good as new. Simply, tap 2-3 holes for each tooth, make a screw with broad top, loctite in and machine the tooth to shape with an angle grinder.
    https://i.imgur.com/iYT1f2e.jpg
    https://i.imgur.com/uwD1py2.jpg
    https://i.imgur.com/d8KSS7n.jpg
    May 2010
    NY, USA
    66
    11
    Very creative solution!!!
    Apr 2018
    3,800
    1711
    Quote Originally Posted by SLK001 View Post
    What if he used aircraft grade milspec extruded billet plastic ? And, don't forget, it's 3D printed !
