Need help with SB rotary table
Results 1 to 4 of 4
    Apr 2010
    Des Moines, IA
    43
    5
    Default Need help with SB rotary table
    I purchased a small South Bend rotary table awhile back. From what I've read online, the arm of this table is supposed to swing away to disengage the worm gear from the table. However, I haven't been able to figure out how to swing the arm out. Is there a latch or locking mechanism somewhere that I'm not seeing?
    Aug 2013
    809
    491
    216
    A photo might help...
    Apr 2007
    Minneapolis, MN
    1,466
    87
    415
    There is a set screw with a spring and ball that locks into a detent.
    You might have to back out the set screw.
    Rob
    Attached Thumbnails Attached Thumbnails sbl-1_li.jpg   sbl-3_li.jpg   sbl-2_li.jpg
  4. Likes VSAncona liked this post
    Apr 2010
    Des Moines, IA
    43
    5
    Thanks Rob! That did the trick. Someone had tightened that set screw down all the way.
    Vince
