Need to make some 1/4 30 tpi screws
Results 1 to 10 of 10
    Dec 2017
    Connecticut
    25
    9
    8
    Default Need to make some 1/4 30 tpi screws
    My single tumbler SB 9" lathe does not offer 30 tpi which is what I need. In fact I need to make about 30 of 'em for a steam engine I'm rebuilding.Can it be done? The SB 13" @ work is also single tumbler and the big Hendey, although double tumbler won't cut 30 tpi.
    How would you approach this problem?
    Sep 2014
    Arizona
    799
    572
    258
    I’d look for a 30TPI die if it’s a one-time job.
    Dec 2015
    Connecticut
    445
    22
    127
    1/4-3 Thread, 1" Outside Diam High Speed 39332 - MSC
    Oct 2012
    NE Ohio USA
    586
    108
    209
    Quote Originally Posted by Machdaddy View Post
    On my Sheldon I used the 20 TPI QCGB setting and changed the drive gear from 1:1 to 1.5:1. That gave me 30TPI. In my case the stud gear is 32 and the drive gear is 32 so I changed the drive gear to 48 (1.5 to 1). You would have to apply the calc to gears in your gear train. Hope this helps.
    Edit: Same gears also gave me 27TPI using the 18TPI QCGB setting.
    Best Regards,
    Bob
  5. Likes old_dave liked this post
    Sep 2010
    moscow,ohio
    5,517
    522
    1704
    42T screw gear, with the normal 20T stud.
    Same 42T gear also lets you cut 27tpi
    Edit- I didn't catch the single tumbler and was assuming 9" workshop model A...
    Jul 2010
    Virginia, USA
    3,359
    84
    589
    This is a single tumbler machine? You can really only change the stud gear. How many teeth are on it now?
    allan
    Nov 2007
    marysville ohio
    9,077
    2548
    5902
    I would just thread mill them. Easy peasy.
  9. #8
    Jun 2010
    Kansas
    299
    23
    1/4x30 die is not very common as you know. Any 30 tpi is going to hard to find.
    Here is a screen shot of where you can get such a die.
    1/4" X 3 TPI UNS
    Chet
  10. #9
    Sep 2014
    Arizona
    799
    572
    258
    Quote Originally Posted by moonlight machine View Post
    Says the guy with a CNC.
  11. Likes Rudd, Christian James liked this post
  12. #10
    Jul 2003
    savannah, jaw-ja
    1,634
    1007
    363
    A little less expensive, and sold for dollars, not pounds..
    1/4-3 Special Pitch Round Die, 1" Outside Diameter - High Speed Steel
    30 TPI is getting into die country for me, finer than I'd like to single point.
