New lathe
Results 1 to 17 of 17
Thread: New lathe
    Oct 2019
    CANADA
    Ontario
    9
    Default New lathe
    I just dragged home a South Bend 9Ē lathe. I donít even know where to start putting it together.
    It came with two flat belts, but the pulley on the motor is a V belt pulley.
    Once I figure out how to post pictures on here I will.
  2. Likes DavidR8 liked this post
  3. #2
    Jan 2019
    North Carolina
    229
    26
    40
    Just make an imgur album, itís easier honestly. Whatever you do please donít use photobucket.
    Oct 2019
    CANADA
    Ontario
    9
    Quote Originally Posted by naru View Post
    Just make an imgur album, it’s easier honestly. Whatever you do please don’t use photobucket.
    Ok, I’ll check out imgur tonight. Thanks
    It’s serial number 70677. 9 inch with a 3 1/2 foot bed. It’s pretty complete, from what I can tell.
    The one belt looks like a Honda timing belt, the other one looks like a serpentine belt from a car.
    The motor turns freely but just smokes when I plug it in, doesn’t matter how I wire the plug.
    Everything on the lathe half looks good, everything turns, I don’t see anything broken or abused.
    Will this have an internal gearbox with oil that needs changing? I didn’t see any drain plugs or fill plugs
    Jan 2019
    North Carolina
    229
    26
    40
    If itís anything like my old 13Ē there should be 2 oil cups on the headstock, one near each bearing. A little below there would be two 1/8Ē NPT plugs that can be removed to drain the oil. Thereís nothing really that has an oil reservoir per say, the headstock and apron are really the only places that hold oil. Everything else uses oil wicks that rely on the user to ensure the oil is topped off on them.
    The motor probably needs to be rewound if itís smoking when plugged in. Is that happening before you turn the switch on? Are you running the correct voltage for the motor? Did it come with a plug on it or was it bare wire ends and you put the plug on it?
    Canít be much help with the belts if your step pulley is set up for V belts. What style is it? Is the motor under the headstock, behind it, or above it?
    Those pictures would help tremendously.
    Oct 2019
    CANADA
    Ontario
    9
    How do you find my imgur account?
    Newsouthbendlathe24
    I donít have a switch for the motor. I wired a plug up to the two bare wires.
    The motor is a 110V motor, 1/4 hp
    Oct 2019
    CANADA
    Ontario
    9
    I think it might just be newsouthbendlathe, no 24
    Jan 2019
    North Carolina
    229
    26
    40
    When you make an album just copy the link in the address bar and post it here.
  9. #8
    Oct 2019
    CANADA
    Ontario
    9
  10. #9
    Oct 2019
    CANADA
    Ontario
    9
    Did that work for you?
  11. #10
    Jan 2019
    North Carolina
    229
    26
    40
    No but hereís your link I believe. New to me lathe - Album on Imgur
    If this isnít yours please correct me.
  12. #11
    Sep 2009
    Phoenix,AZ
    1,838
    2806
    472
    Learn how to post pictures here ,saves lots of time going to links,and if the link goes bad pictures will still be here! Throw the timing belt away!! You use a regular V belt that fits the groove on the motor and the inside drives the big CS pulley from the inside. Weird but that is how SB did it ! As for me I normally won't be bothered to go to a link to view pictures,but for you being new I did.
    PS that's a oldy with the top oilers.And forget about rewinding that motor ,just buy a emplacement as even new it will be a lot cheaper than rewinding even if you can get done.
  13. #12
    Oct 2019
    CANADA
    Ontario
    9
    Nope, thatís mine!! Thatís about the best I could figure out how to put it together
  14. #13
    Oct 2019
    CANADA
    Ontario
    9
    Quote Originally Posted by JohnEvans View Post
    I will see if I can figure out how to post pictures here then, Iím obviously new here.
    How do I go about sourcing the correct belts?
  15. #14
    Langley, B.C.
    1,744
    368
    1018
    ...Learn how to post pictures here ,saves lots of time going to links,and if the link goes bad pictures will still be here!
    Yeah, posting pics on this site is easy peasy--no need for off-site hosting...
  16. #15
    Oct 2019
    CANADA
    Ontario
    9
    Quote Originally Posted by LKeithR View Post
    Ok.... how do I do that? Iím not sure if Iím missing something on how to post pics here
  17. #16
    Jun 2016
    New York
    1,772
    1055
    816
    Quote Originally Posted by Chicken Lights View Post
    in the utilities bar at the top of the window you get when posting, there is a tree in a frame. click on that and then you can select an image from your computer and upload it. I send them form my phone to my laptop then select them, but there is another way that results in nice full size images so you don't have to click on them, but I haven't done it that way yet. someone posted how to do it, but for some reason either I didn't try hard enough, or it was some kind of OS incompatibility.
    (yea, I'll blame it on that!! )
  18. #17
    Mar 2010
    Utah
    718
    58
    49
    quote {How do I go about sourcing the correct belts?}
    Goto McMaster-Carr catalog
    Click on V belts
    Goto the information page on V belts
    Read how to measure and order V belts
    Hope this helps some..
