New to machining and the South Bend 9. Questions questions questions!
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
    Feb 2020
    CANADA
    Alberta
    17
    17
    8
    Default New to machining and the South Bend 9. Questions questions questions!
    Hi there.
    I recently purchased this South Bend 9 to attempt to do some light duty automotive part machining. I'm hoping this lathe will satisfy my need to cut to length pushrods and trim piston barrels for their cases.
    It was very clearly used as a 'farm' lathe here in Western Canada, as there is definitely some odd things about it (like the actual pant belt as a belt and the large wooden pulley) that suggest its been used remotely.
    I'm having a hard time identifying which model it is. It doesn't have the driven cross feed, and it looks as though one of the rails was replaced (the one with the serial number). Is there another way to identify this?
    As it doesn't have any instructions (and I don't know what model) is there any literature/websites that talk about what gear combos are used for what pitches? Can the lathe be used to cut metric threads?
    I'm assuming that all of this info exists here on the forum. Any pointers/links to find the answers would be appreciated. I'm new to this, and am open to learning from your experiences.
    Jul 2004
    Houston, TX USA
    30,444
    9C I'd guess
    Handy pub they put out
    http://vintagemachinery.org/pubs/1617/17726.pdf
    ph
  3. Likes Steven-Canada, Oildrips liked this post
    Feb 2020
    CANADA
    Alberta
    17
    17
    8
    Thanks for this. That was my guess as well. I'm super new to this and appreciate the info.
    Feb 2020
    CANADA
    Alberta
    17
    17
    8
    Looking at that link, page 25 of the book has an idler gear. This is one I don't have.
    Sep 2009
    Phoenix,AZ
    1,837
    2804
    472
    Well I don't see any change gears and without them you will not be cutting threads ,plus to do metric you will need transposing gear[s]. If you are missing those gears and only the one chuck and if the lathe is well worn you might end up with more money in it than if you would buy a better machine. Pretty much all USA made smaller lathes will need the transposing gears to do metric. The small Asian [Chinese] lathes normally will cut metric by changing a few gears that they come with. And here I am refering to 12" and larger lathes.
    Feb 2020
    CANADA
    Alberta
    17
    17
    8
    Thanks for the reply. I have a big stack of change gears that came with the lathe, and from what I can tell I'm missing the compound 18/72 gear/idler. It also came with a 4 jaw chuck. As far as it being warn, I still need to go through the lathe itself. It only showed up on Sunday. Can you explain the transposing gears?
    Jul 2004
    Houston, TX USA
    30,444
    Quote Originally Posted by Oildrips View Post
    Here is the "imperial" SB 9C chart - normally riveted to left end gear cover. Metric a whole different story, probably costing more than the lathe and its usual tooling for the set SB sold
    Here is an example of Metric-ing
    Looking at the chart above for 9C, say you were set up for 8 TPI - with the 32T stud gear and the 32 T Screw gear and the 80T idler - exactly as in Figure 2
    If you removed the 80T and stuck in a 127T / 100T compound (or a very similar ratio 80T / 63T) you could cut 2.5 mm thread. That is just one of many, only a few of which will be "easy" like the example
    The math that determines this is using these values:
    8TPI = .125" pitch (because 1 / 8 = .125, the reciprocal of 8)
    127/100 = a ratio of 1.27 to 1
    .125 / 1.27 = .098425" pitch
    .098425 X 25.4 = 2.5 mm pitch
  9. Likes Oildrips liked this post
  10. #8
    Feb 2020
    CANADA
    Alberta
    17
    17
    8
    Thanks for the tutorial on this stuff. Very helpful indeed. When I look at the picture you attached, it looks like there are 2 different slide rails to mount the gears on. My lathe only has one ( so like figure 2). Nothing was cut off, just like it wasn't there in the first place. Is this normal?
  11. #9
    May 2011
    New Jersey
    2,422
    213
    1309
    Wooden pully? I can't believe we actually allow this junk on here anymore.
  12. #10
    Feb 2020
    CANADA
    Alberta
    17
    17
    8
    Quote Originally Posted by plastikdreams View Post
    Not sure where you are going with this comment, or why its necessary.
  13. #11
    Jan 2019
    Virginia
    10
    That's the way mine is too. I'm beginning to wonder if mine actually is a 9C or some predecessor? Everything else is just like the 9C but I also have the one-armed gear banjo. I'll have a look at my threading chart on the gear cover and my change gear set tonight.
  14. Likes Oildrips liked this post
  15. #12
    Jan 2014
    North Carolina
    473
    17
    135
    If that picture is your lathe and you do have a stack of change gears to go with it, you probably can cut most common threads. What gears you have will determine what threads you can cut. I wouldn't worry too much about the wooden pulley. It'll probably work OK until you can find the correct one.
    If you didn't get the covers for the end gears and the back gears your lathe will work just fine but be REALLY careful you don't get fingers or clothing caught in them because that could lead to very serious injury. I have a Workshop 9" lathe, Model C that looks a lot like that one (no wooden pulley) and it works very well and cuts all the threads I need.
    If you want to keep it, I'd try to find the gear covers and the correct pulley for the countershaft but you should be OK for starters.
    Get and read the South Bend publication How to Run a Lathe. You can find PDF copies on line. It will answer a lot of the questions you have.
    So far as cutting metric threads, you'd probably be better off to buy a lathe that has "native" metric threading ability.
  16. Likes Oildrips liked this post
  17. #13
    Feb 2020
    CANADA
    Alberta
    17
    17
    8
    Glad I'm not alone. I'd appreciate it if you can share your findings. Are the 1 arm and 2 arm banjos are interchangeable? Do you know if the reason for the 2 armed banjos is to add additional capabilities for threads?
  18. #14
    May 2011
    New Jersey
    2,422
    213
    1309
    I was going with íts got a wooden pully, it should be on a hobbyists site not this one. I'm sorry if I seem harsh but it's the truth.
  19. #15
    Feb 2020
    CANADA
    Alberta
    17
    17
    8
    Thanks for your post. I've been very hesitant to play with the lathe without the covers for exactly this reason. The PO also mounted the power switch at thigh height, making it super easy to turn on.
    I found all the gear covers and the countershaft/pulleys and have them already on the way. Safety Bear's top priority.
  20. #16
    Feb 2020
    CANADA
    Alberta
    17
    17
    8
    Yes. It has a wooden pulley. Does it matter? It also has some cowboy's leather belt driving the pulleys. Still spins.
    I did my best to express the fact that I'm new to machining and this lathe in the title 'New to machining and the South Bend 9. Questions questions questions!', so if the topic is below you, I'm not sure why you'd bother to keep reading and then comment. I'm sorry if I seem harsh, but it was stated pretty clearly that I'm looking for guidance.
    I respect the fact you already know more about lathes and machining than I do. I don't pretend to know anything, so I try to find the best resources around. I'm not interested in having heart surgery performed by someone that did their schooling by watching youtube videos. I'd like to learn from the best. Rather than shut people down who want to learn and make them feel not welcome, why not offer something positive to help out someone new instead of looking down on them and what they have to work with? It costs nothing to be helpful.
  21. Likes mach2, MichaelP liked this post
  22. #17
    May 2011
    New Jersey
    2,422
    213
    1309
    Well, this is the antique section of the site not the cobbled together shitbox southbend 9" section. Just because you don't know what you are doing doesn't make it ok to have a wooden pully on a lathe that you intend to actually use.
    These are the best resources around you are 100% correct
  23. #18
    Feb 2020
    CANADA
    Alberta
    17
    17
    8
    Seems this may have been lost on you a long time ago
    Necessity is the mother of invention - Wikipedia
    I'm ok if you want to keep throwing out the insults. Whatever is going to make you feel like the better person.
  24. Likes dalmatiangirl61 liked this post
  25. #19
    May 2011
    New Jersey
    2,422
    213
    1309
    It's not about being a better person, really, I dont even own a machine save for a small Lincoln mig welder. It the premise of this site. I'm all for allowing anyone who wants to learn on this site, there are some that will right tooth and neck to keep them off here. Its not about the machine... unfortunately to some it is. But when it comes down to stuff that's not rigged it strikes a cord.
    I welcome you to learn as much as possible here.
  26. #20
    Jul 2004
    Houston, TX USA
    30,444
    Amazing, and you could have fooled me. Long time member Gary made a WOODEN pulley for his ancient Le Blond - and it was admired by people in the Antique forum
    My brand new 1909 LeBlond came home today
    Turns out that such things are frowned on in the SB section!
    How is that?
