New to me 1929 wide (heavy?) 9" long bed and overhead silent drive casting trade - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 63
  1. #21
    Apr 2016
    446
    177
    184
    - drilled and pressed in a ball oiler for the compound. Filed holes in the side of the oiler so some of the oil would dribble out the side and run down to the dovetail ways. The rest will oil the screw/ nut.​
  2. #22
    Apr 2016
    446
    177
    184
    Bit of a milestone today - finished the headstock.
    Got the back gear out, cleaned out the 2 ball oilers and the gears
    took the tumbler reverse apart, cleaned everything up and replaced the felts. Had to use a puller to get the stud gear off, so I could undo these two screws and remove the whole assembly.
    Got rid of paint from where paint should not be as well
    Pressed the spindle apart, put the spindle pulley in the spooge tank and gave everything a good clean. Very little scoring on the spindle and no obvious marks on the bearings, which is awesome. Super happy about that.
    Ain't she pretty?
  3. #23
    Apr 2016
    446
    177
    184
    Dissassembled the QCGB today, remind me not to do this again in a hurry - oh wait, I have to take it apart again Boy, what a hassle. I was tempted to leave this as is, but all the felts that I could see were solid blocks of nastiness and several other bits of the lathe had blocked oil holes and the like, so in I went.
    wasn't too hard to get apart, though I forgot to line up the splined type gear on the back shaft with the key, which caused an upset. Longitudinal pin in that gear wasn't too hard to get out either. No pin in the front shaft nut.
    Getting it back together though, oh boy. It was all going swimmingly until it came to getting the far left gear on the back shaft pressed on. Tried all kinds of approaches, including a brass drift (warning, these gears are surprisingly soft!). What finally worked was spacing the center sliding gear and the right hand gear apart, and then driving the shaft into the housing.
    Front (lower?) shaft was a royal pain, raised a burr on the thread so had to take everything apart again, but finally got it all together.
    There's a periodic binding that I think is being caused by the back left spline type gear as it no longer freely rotates on its shaft but binds once a revolution. Probably a burr or upset from pushing the key into it. I'll take it apart tomorrow again and see what's going on. At least this time will be quicker!
    Little wear on the gears from what I can see
    took some 320 grit wet'n'dry to the threading plate and very carefully sanded the raised part of the plate. Makes it a lot easier to read now.
  4. #24
    Apr 2016
    446
    177
    184
    Taking it apart and putting it back together the second time was much quicker and less dramatic The rotating spline type gear had an upset from the key being smacked into it and the shaft had a burr on the side of the groove that the gear pin goes into. Cleaned those up and any damage I'd caused wanging on the gears with a brass drift. Also cleaned up the keyways and bores of both of those gears, so just getting them on the shaft was easier. Now everything rotates smoothly in all gears with no binding whatsoever. Phew!
    Also cut a little oiling channel for the sliding pin on the range selector. There is an oil hole for it, but you'd have to be a contortionist to get to it. So I connected the pivot bore with the existing oil hole, so any oil that comes out of the pivot should flow down there.
  5. #25
    Apr 2016
    446
    177
    184
    what a fiddle fart this was - making a couple of standoffs for the gear cover. First one that I made out of piece of 12mm boring bar shank had a 8-32 tap broken off in it on the last step. Grr. 2nd one ended up too short and then when I made the 3rd and 4th, they didn't line up with the holes in the guard. Had to gently bend one to get it to fit. No wonder the screws that came with it were bent.
    should be easier to get on and off now though
    still need to make a suitable thumb screw for the bit that bolts to the gear box
    In the middle of getting p!ssed off with all of this I took a break to polish up the labels on the gear box. That made me feel better
  6. #26
    Apr 2016
    446
    177
    184
    got a nice FIMS #2 tool post off eBay, so cleaned and regreased it, then made a bolt and T-nut for it. I think it'll be a real nice, solid tool post to use. Now I have to make some holders for it...
  7. #27
    Apr 2016
    446
    177
    184
    got the banjo together, made an oiler tube for the gearbox input shaft and made a small spring out of a hacksaw blade for the ball detent, as suggested by Peterj.
    way wipers for the carriage next!
  8. #28
    Apr 2016
    446
    177
    184
    Finished up the remaining way wipers. Hope I don't have to do that again, what a pain. Made even worse by one of them spanging off my face shield and disappearing into my garage for a couple of hours!
    they aren't perfect, but they'll do and I sure as shinola don't want to do this again!
  9. #29
    Dec 2020
    New Jersey
    8
    Are you selling this for parts or are you rebuilding it? If you are looking to sell parts, I would be interested in the apron.
    Joe gin
  10. #30
    Apr 2016
    446
    177
    184
    definitely rebuilding it to use Let me know if you need any dimensions or drawings of the apron parts, it isn't back on the lathe yet so it would be relatively trivial to take to pieces again.
  11. #31
    Apr 2016
    446
    177
    184
    alright, large side track into making my wife's Christmas present (The Nutcrusher Mk1) and an even larger side track into fixing my current lathe has slowed me waaaay down. I was going to make the tailstock extension first, but I've decided to put that on hold and work on getting the lathe up and running.
    However, in the meantime I figured I'd finish the tailstock extension nut so I could get my friend's 1/2-10LH acme tap back to him. That one piece was a pig to drill and tap, hopefully never again
  12. Likes clay27bsouthbend liked this post
  13. #32
    Jan 2018
    Florida
    46
    58
    10
    Nice work. Can you post picks of the bed. I am curious about how much ware it has.
  14. #33
    Apr 2016
    446
    177
    184
    thanks! As to bed wear, alot is the easy answer The ways have a definite lip and the matching carriage Vs were worn as well. I'll have to see if it's enough to need to shim the rack and leadscrew down a bit when it all goes back together. If I can get to it to take a picture I'll see if I can get a good photo of the way wear.
  15. Likes DonTen liked this post
  16. #34
    Apr 2016
    446
    177
    184
    took a pic - the bed is currently propped up against a shelf at the back of the garage
    couldn't get a good pic with light behind a parallel held against the V, but with feeler gauges the gap was between 0.005"(wouldn't really go in) and 0.003" slipped in easily, so my guess is 0.004" or thereabouts. Less than I expected to be honest.
  17. #35
    Apr 2016
    446
    177
    184
    finished the extended tailstock screw. Made it in two parts - the handle end and (cheating) 1/2-10LH acme threaded rod Overshot the end of the threaded rod by 1/2 thou, so it ended up being a light press fit into the handle end. Added some JB weld to make sure, but if that isn't enough I'll cross pin it.
    with the extended nut
    and compared to the old screw
  18. #36
    Apr 2016
    446
    177
    184
    roughed in the extension tube. Couldn't thread it as I'm having problems with the halfnuts jamming up on my current lathe. I'll finish this off when the SB is back together.
    bored a recess in the tailstock nut/ screw holder for a thrust bearing. The new screw has a little extra length for one at the other end, but that'll have to wait for the extension tube to be finished.
  19. Likes pavt liked this post
  20. #37
    Apr 2016
    446
    177
    184
    pushing the limits of my little 4x6 bandsaw
    motor mount and countershaft in waiting. Got the pillow blocks ages ago from an estate sale for $1 and the plate was some piece of scientific equipment that my college scrapped.
    countershaft pulleys in waiting These will have to wait until the SB is running. I'll use an old treadmill pulley to get started.
  21. #38
    Sep 2010
    moscow,ohio
    6,531
    675
    2267
    are you going to make the countershaft pulleys and shaft as one single piece?
    secured to the countershaft frame with the bolt on bearing blocks?
    would save some steps in the process, as no drilling/boring operations would be required
  22. #39
    Apr 2016
    446
    177
    184
    that's a pretty neat idea, but I won't be going that route as I'd have to remove a considerable amount of material to make the shaft one piece with the pulleys.
    Current plan is to cut off a long piece of the smallest diameter round, drill it for centers and turn that down for ~2/3 of its length. Then bore out larger pieces and press/ pin them to the larger chunk. Drill and ream the whole lot for the 1/2" shaft, drill and tap for set screws to hold it to the shaft. Then put the whole thing on a 1/2" shaft drilled for centers, mount it between centers and turn the pulleys and groove them for a J10 poly V belt.
    I did that for a new poly-v countershaft and spindle pulley set for my current lathe which worked out really well, though the parts were smaller than these ones.
  23. Likes 1yesca liked this post
  24. #40
    Apr 2016
    446
    177
    184
    trundling along - finished the countershaft and temporary pulley. The large diameter part of that hub was the last piece of the trailer axle roadside find that I used for the tailstock extension tube
    and finished the motor plate this morning using the bit cut off the bigger plate
    to finish that all up I'll need to take the countershaft back off and cut two slots for the screws sticking out of the motor plate. That'll allow me to adjust the tension of the motor>countershaft belt from the front.
