No felt?
Results 1 to 7 of 7
Thread: No felt?
    Aug 2021
    NORWAY
    14
    21
    Default No felt?
    Hello again
    I am refurbishing my Aasbrink which is a clone of the SB9. I have put back the headstock together just to see how it looked and must say I am rather pleased.
    But when I took it apart there was no felt in the oilers or bearings. And there is just this small grove at the top of the bearing. Should there be felt in the oil cups or in that small grove? What do you guy's think?
    Sent fra min LYA-L29 via Tapatalk
    Feb 2011
    3,015
    2838
    1436
    It may depend on how Aasbrink made their version, but I would say yes for the oil hole, no for the oil groove, however I would want something in the front slot where the bearing is clamped. Many lathes will have felt or paper-board in there to keep dirt and chips from migrating into the bearing. You might do an initial bearing adjustment to see how wide the compressed gap is and what materials are available to you to make a filler for it. Something that'll hold it's shape but also not inhibit future bearing adjustment.
    Feb 2015
    Florida
    1,125
    338
    Your lathe is based on a pre-war design. The lubrication system was totally flow-thru and had no felts. You are supposed to fill the cups once an hour for the first 100 hours, then twice a day after.
  4. Likes M.B. Naegle liked this post
    Sep 2004
    Alabama
    634
    130
    Original design had no felts. I would put felt in the oil cup to slow the oil flow and to filter the oil. I would also put felt into the bearing clamp slot. That felt would keep debris out, and serve as a wick to retain oil.
    Apr 2016
    563
    239
    224
    see how quickly the oil empties out of the cup in use. If it's gone in a few minutes, add some felt to slow it down.
    Feb 2015
    Florida
    1,125
    338
    Quote Originally Posted by mattthemuppet View Post
    If the oil is gone in a few minutes, you might want to adjust your bearing clearances.
    Apr 2016
    563
    239
    224
    it's as tight as I can get it without binding, about 1 1/2 thou clearance with the spindle lift test. I have a feeling someone remade the bearings sometime in the last 90 years as I've never seen any pre-30s SB9s with one piece bronze bearings. They did a good job but went a bit undersized on the bearing OD as it had a brass shim when I took it apart, which needed replacing when I put it back together.
    I just flood it with oil. Lathe runs great, no chatter or deflection I've been able to detect so far.
