No holes for mounting thread dial on my 9"... huh
Results 1 to 7 of 7
    Sep 2019
    CANADA
    Ontario
    10
    17
    13
    Default No holes for mounting thread dial on my 9"... huh
    My 9" is an early one with chrome spring loaded oilers on the top of the spindle. It has the big cast gear cover that doesn't latch to anything. The gear chart is on the end but only says Workshop precision and doesn't specify A B or C. It does say 9" though and it looks like a 9C. The gears are manually interchanged like a "c" which I thought it was. I was cleaning the apron and noticed no place to mount a threading dial. Has one hole to oil the carriage gears in the front, but thats it. So does this mean I couldn't mount one without machining and drilling the carriage or was there another way to mount on this lathe? Any options? Thank you
    Jul 2010
    Virginia, USA
    3,419
    86
    616
    If the lathe did not have a dial originally, it won't have the holes. If you bought the dial later, it came with instructions: http://www.wswells.com/data/howto/pa...ial-ATT-94.jpg
    allan
  3. Likes mydadslathe liked this post
    Jul 2004
    Houston, TX USA
    29,492
    Thumbnails show the two loose change gear versions, B with apron clutch (and power cross feed) and C with neither
  5. Likes mydadslathe liked this post
  6. #4
    Feb 2004
    peekskill, NY
    24,219
    4414
    Quote Originally Posted by kitno455 View Post
    allan
    Interesting. Same as if one purchases a 10L that never had a lever collet closer installed. The owner
    has to drill and tap the hole on the headstock boss for the pin that holds the link. Was a bit nerve
    wracking that. I was sure I was going to destroy a perfectly good headstock....
  7. Likes mydadslathe liked this post
  8. #5
    Sep 2019
    CANADA
    Ontario
    10
    17
    13
    I think this model might pre date the abc designations. I now see the cross slide is much shorter than I see on later models. So confusing. Thanks all.
  9. #6
    Jul 2010
    Virginia, USA
    3,419
    86
    616
    Quote Originally Posted by mydadslathe View Post
    Sounds like a model 5: South Bend Model 5, 205, 405 & Type 15 lathes
    allan
  10. #7
    Sep 2019
    CANADA
    Ontario
    10
    17
    13
    Thank you very much Allen. Looks like a 415 according to the gear cover. Serial 62221 1934 or 35.
