No Serial Number Found on My 14 1/2
Jfonce007
Jul 14, 2018
Hi there....help!!! I can'
t find a stamped number on my SB 14 1/12....and I am looking for a left side motor housing panel too!
Thanks for any help!!
JF
The only likely reason a SB lathe would be missing its serial number is if the bed has been reground significantly.
It happened to mine after removing 0.050” of material. Still need to put it back...
All the way to the tailstock end, between the flat surface at the front of the tailstock slide, and the front V way. Clean the recessed surface between those two ways about ten inches in from the end. To the end.
I hope that isn't Greek to everyone accept me. Dig down to bare iron.
Comstockfreind 's explanation may be better. Its less complicated.
Get one of those small wire brushes about the size of a tooth brush.Brush the area where the number is supposed to be.Old dirt doesn't come off easily.Especially imbeded.
